It is currently Sat Feb 16, 2019 3:06 pm
PostPosted: Fri Mar 02, 2018 3:05 am
RIP 2001 SSEi
Hey guys today I put on my ported throttle body (From ZZP) on my bonnie and all of a sudden its just misfiring and idling horribly. Then it almost kills itself just sitting and with then rev high to stop it from dieing. If i give it some throttle it will take an unusual time getting back down to idling RPMs aswell which is a weird behavior. I've taken it off twice and back on and I dont think there is any way that air could be escaping from it. I bought a new MAF to be sure and that was a big waist of money and I tried replacing the other 2 sensors from my original TB and it started up better but then continued to do the same thing. I really dont know how Just replacing the TB could of done this. Also when i took it out on a drive after puting in the new MAF it drives just fine and there are no signs of misfire at all, then if you are at a stop for more then a few seconds it will go right back to its misfire.
I also used exhaust wrap on my cross over on my headers and used the black silicone spray on it, but the mating surface to the TB was covered with a plastic bag and had a rag in it to protect it. Just mentioning this incase for whatever reason its relevant. Any help would be appreciated ASAP as I dont feel comfortable in driving it in its condition.
Bonnie - 2001 Bonneville SSEi RIP in spaghetti never forgetti
Goldein - 2000 Bonneville SSEi Live forever.
2.25" I/C, Machined LIM, 42.5 Injectors, 3.0 S/C Pulley, 72mm TB, SD Headers+ZZP DP+magnaflow Catback, ZZP tune.
PostPosted: Fri Mar 02, 2018 10:08 am
Sounds like a vacuum leak to me. Check all the rubber fittings, they love to crack, especially if you bumped them during the install.
-Andrew-
PostPosted: Fri Mar 02, 2018 11:28 am
you got scan data?
if the miss is only at idle, I would first check the IAC. and verify that TP is correct value
just for giggles, unplug the maf and see how it runs.
PostPosted: Fri Mar 02, 2018 3:05 pm
RIP 2001 SSEi
96 SSEi wrote:
you got scan data?
Not sure what to check? Because like I said I did switch out the reused one from ZZP for my own. Is there a certain way to put it in that i dont know?
PostPosted: Fri Mar 02, 2018 3:27 pm
ok, did you replace the throttle body gasket?, i think its paper and its NOT reusable.
that would cause a miss at near idle
PostPosted: Fri Mar 02, 2018 4:14 pm
RIP 2001 SSEi
You were absolutely right. Thanks so much for the advice. A vacuum line basically fell apart that I didnt notice because it was under part of the wiring harness. Now she runs great.
There are no new unread posts for this topic. 99+ throttle body and maf
1337ssei
Mon Jun 02, 2008 7:40 am
lammers View the latest post
There are no new unread posts for this topic. N* throttle body?
irish91983
Thu Jul 12, 2012 5:48 pm
There are no new unread posts for this topic. cleaned the throttle body but...
SSEI173
11
1870
Tue Jun 11, 2013 10:59 pm
Trinity View the latest post
There are no new unread posts for this topic. Bigger throttle body?
fleettech2252004
Tue Jan 13, 2009 9:09 pm
sandrock View the latest post
There are no new unread posts for this topic. throttle body spacer
95se
Tue Jul 23, 2013 6:48 am
95naSTA View the latest post
