It is currently Sun Feb 17, 2019 7:49 pm
PostPosted: Sat Jul 29, 2017 10:13 pm
RIP 2001 SSEi
Hey guys, been looking into getting some Speed daddy headers because they are very much affordable but I have alot of questions and every thread seems to be just bits and pieces of what I need. First of all I was thinking about just getting it done by a shop because I know its a fairly big job and I dont own a welder. I bought a ZZP downpipe with a cat so Im sure thats gonna have to be fabbed to keep the cat (So i've been told.)
So my main questions are what I need for the job to get done.
I've read that I need to get a fan spacer kit to make the fan motor closer to the fan so it does not touch the headers.
Also read that I need a W body transmission dipstick and possibly a oil dipstick?
One member has had to cut out a portion of their motor mount is everyone having to do that?
I know a new flex pipe is a necessity on these.
Do I need an extended O2 censor? I've heard some do and some dont.
let me know if ^^^ these are required to install before the big header install happens.
I'd like to know the basic processes because Im completely clueless. Are you guys having to take the motor mounts off? Can the headers be cut to meet a ZZP downpipe? I've not seen any tutorials or walk through for these, just little bits and pieces of problems people were having installing them and tips.
Let me know if you've done a header install and if I need anything else to get the job done, I feel like they are a bit above my expertise in installing them so I'm going to be calling the local shops around me to see if they will even give me quotes. hopefully it wouldn't be to expensive.
Bonnie - 2001 Bonneville SSEi RIP in spaghetti never forgetti
Goldein - 2000 Bonneville SSEi Live forever.
2.25" I/C, Machined LIM, 42.5 Injectors, 3.0 S/C Pulley, 72mm TB, SD Headers+ZZP DP+magnaflow Catback, ZZP tune.
PostPosted: Sat Jul 29, 2017 11:12 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
If you don't have a welder, then yes have a shop do the job.
I've only done this on pre-00 cars. But your list is complete. O2 sensor needs to be extended on the pre-00.
One thing you missed is the crossover pipe might not be bent correctly. It's close, but make sure the shop doesn't try to strong-arm it on. If it's not *perfect* it needs to be cut and re-welded to fit, otherwise the lower joint will leak.
Runs:
Doesn't run:
PostPosted: Sat Jul 29, 2017 11:42 pm
RIP 2001 SSEi
Thank you so much for the tip on the crossover. So about the dipsticks, is it both for sure or just the tranny? Also do you use header wrap on the crossover? I imagine that would help alot being right under the TB. I appreciate the quick response Matt.
PostPosted: Sun Jul 30, 2017 12:58 pm
Year and Trim: 2001 SSEi
Just the trans dipstick. I had no problems with the original oil dipstick when putting SD headers in.
PostPosted: Mon Jul 31, 2017 12:51 pm
2005 Bonneville GXP *Sold*
X2 for just the trans dipstick (for the '00-'05 anyway).
>>Get one from a Grand Prix for any of the years the headers are listed for.
BTW, the baffle on the fan motor is only an issue on the Grand Prix. There is plenty-o-clearance on the Bonneville.
2006 Saab 9-7x 5.3i
2005 Pontiac Bonneville GXP / 4.6L Northstar *Sold*
2001 Olds Aurora 4.0 w/GXP Exhaust and High-flow cat (OSV Wannabe) *Sold*
2001 Pontiac Bonneville SSEi, 3.4" MPS, Intense Tune, SD headers, high-flow Cat, GXP exhaust, Modified Air Intake, 180* thermostat, GXP: 18" GXP wheels w/255/45/18 tires, CF Trim, Brakes and Strut Tower Brace. SOON TO HAVE: GXP Swaybars.
1972 Olds Cutlass Convertible / 461ci Olds / TH400 / 3.08 Posi. 13.62 @ 99.7 MPH......Got torque?
Yes, I seem to be drawn to GM's orphaned cars......
PostPosted: Sat Aug 05, 2017 3:47 am
RIP 2001 SSEi
Ok thank you for you're info. Not sure when Im going to get this done, I called around and the cheapest shop that gave me a rough quote was 500$. So im thinking of maybe buying a set of ZZP headers because I alrdy have the downpipe and it would bolt right up to it and have a go at it myself? Not sure on how to go about the whole process or if im crazy to attempt on my own because I've never done anything like this and its a big big job to do. Let me know your opinion.
There are no new unread posts for this topic. header install
deano55
35
4370
Sun May 06, 2012 3:43 pm
There are no new unread posts for this topic. SLP header install
viper8907
Sun Sep 20, 2009 1:36 am
viper8907 View the latest post
There are no new unread posts for this topic. SD header install 2016
Pair of SSEI
Sat May 14, 2016 11:51 pm
Pair of SSEI View the latest post
There are no new unread posts for this topic. Need Help! stuck with header install
2001SSEi
Sat Apr 04, 2009 7:06 pm
2001SSEi View the latest post
There are no new unread posts for this topic. SLP Exhaust Header Install for 1999 SSEi
99ssei
15
3399
Tue Aug 05, 2008 10:33 am
99ssei View the latest post
