It is currently Wed May 23, 2018 3:03 am
 Post subject: Transmission
PostPosted: Mon Jul 10, 2017 6:37 pm
Year and Trim: 1997 Bonneville
Hello, I have a question about what transmission should I get for durability and performance? I have a 97 bonneville SE, 3800. I believe that the transmission needs to be replaced and I am looking to replace it with a used one. Low budget can not afford new. Thanks for the suggestions.
 Post subject: Re: Transmission
PostPosted: Mon Jul 10, 2017 8:06 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Hm. Well, 4t65, but I think you need to either pcm and harness swap or tune? not sure.
I don't know how much boost it takes to blow the tires off. But I know how much I'm going to use!
Runs:
'93 Pontiac Bonneville SSEi - Twincharged, manual, racecar! Build thread
'97 Chevy Camaro - 3800, T5, T-tops, my DD
'89 Buick LeSabre Limited - winter DD
'97 Buick LeSabre - L67 project
Doesn't run:
PostPosted: Tue Jul 11, 2017 10:53 am
Did the 97 NA cars already have the 4T65? If someone confirms, then your best bet would be to get one from another Bonne or LeSabre with the same final drive ratio, unless you plan to tune.
"Penelope" - 2003 SLE - 172k Miles
2000 Honda S2000 - 52k miles
PostPosted: Tue Jul 11, 2017 9:03 pm
Can someone tell me how to see what one I have?
PostPosted: Tue Jul 11, 2017 10:01 pm
In 97 n/a's had the 60-e. Supercharged cars got the 65-hd.
Easiest way to tell if it's a 60 is if you have a vacuum line running from the throttle body to the transmission in the front.
The shiny think under the connector in the center of this pic is the vacuum modulator that only 60s have.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
74 Yamaha DT175: brap brap, brap
There are no new unread posts for this topic. What transmission is in my car?
ytd1861
Mon Apr 22, 2013 12:17 am
There are no new unread posts for this topic. Transmission Cooler?
LeSabreUltra
11
1702
Thu Jul 17, 2008 1:40 pm
LeSabreUltra View the latest post
There are no new unread posts for this topic. manual transmission
trf_ssei
Mon Feb 23, 2009 1:42 pm
trf_ssei View the latest post
This topic is locked, you cannot edit posts or make further replies. Transmission clunk
dutchman
Wed Jan 13, 2010 8:42 pm
J Wikoff View the latest post
There are no new unread posts for this topic. Transmission Advice
Tricked-T
12
902
Fri Apr 16, 2010 10:43 am
Tricked-T View the latest post
