It is currently Mon Feb 18, 2019 8:46 pm
 Post subject: L67 or northstar TB ?
PostPosted: Sun Apr 17, 2016 6:40 pm
Year and Trim: Bonneville Ssei 1992
Hi am about to swap my L67 series 1 engine to an L32 from a pontiac GT 2007 ,, gonna go with the stock ecm from my 1992 ssei and will need a new Throttlebody for the L32 engine but what do i want ?? a Series II TB or a Northstar throttlebody ? and iv also been told i need an adapter to fit either of these Y`TBs to the L32 engine/charger ,, so what do i want to use ? not looking for anything extreme ,, 400 + is the goal for this project
PostPosted: Mon Apr 18, 2016 11:38 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
How do you plan to tune the PCM for the new motor and setup?
Runs:
Doesn't run:
PostPosted: Mon Apr 18, 2016 2:46 pm
thrue ryan at gmtuners,com
PostPosted: Mon Apr 18, 2016 4:37 pm
'05 STS-4
'97 LeSabre
Northstar TB. Either way you need a throttle body adapter. But 400 is a lot for a M90 setup so you'll need the extra flow
Runs:
Doesn't run:
PostPosted: Mon Apr 18, 2016 9:06 pm
You're in good hands. Great guy to deal with.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Tue Apr 19, 2016 2:05 pm
yepp i know ,, i live in sweden and i dont mess around ,, when il as this time buys an engine from US i allways makes shore it works before ordering ,,, ryan isent a great guy ,, hes pratcticly a GOOD when it comes to this :hail: :hail: :hail:
PostPosted: Tue Apr 19, 2016 2:11 pm
well i can go pretty high in pressure since i will run it on E85 ,, ,, 400 is what im aming for but what ever it will deliver will be better then the series One L67 thats sleeps under the bonnet rigth now and to build performance on that engine isent worth ..
but what would you say in the diffrance between L67 series II TB and a northstar TB ,, since these cars are rare here iv havent got any adie about the difrance in size ,, could you guide me ? and IF the northstar TB it "da *shoot*" for what models are the right TB as i shall seartch for ?
PostPosted: Tue Apr 19, 2016 4:47 pm
'05 STS-4
'97 LeSabre
L67 throttle body is 69mm diameter, Northstar is 75mm.
Which one will work?
1995-older: No
1996-99: Yes, can use either the 3800 MAS (might have to modify slightly) or the Northstar MAS.
2000+: Yes, but need a standalone MAS (such as the LS1 sensor).
Runs:
Doesn't run:
PostPosted: Tue Apr 19, 2016 5:01 pm
1995-older: No
great il think we mean the same as i call it massive airflow sensor and you spells it MAS but im used to call if MAF ?
PostPosted: Tue Apr 19, 2016 9:08 pm
It's the same but MAF is the most common in 3800 world.
05 Suzuki DRZ400S
There are no new unread posts for this topic. v8 northstar
99bonnie
19
1296
Sat Feb 07, 2009 10:49 am
silverws6ta View the latest post
There are no new unread posts for this topic. SUPERCHARGE the NORTHSTAR V8?
mccinima
Fri Feb 18, 2011 1:14 am
BonneMe View the latest post
There are no new unread posts for this topic. northstar swap?
motopsyco
Mon Dec 09, 2013 2:05 pm
repinS View the latest post
There are no new unread posts for this topic. 4.6 Northstar into my 99 SE. How hard to do?
99SilverSE
Thu Aug 07, 2008 10:06 pm
firebuick View the latest post
There are no new unread posts for this topic. Northstar Throttle Body
gweg_b
Thu Mar 13, 2014 8:38 pm
BackwoodsEngineering View the latest post
cron
