It is currently Fri Apr 25, 2025 5:41 pm
PostPosted: Wed Jun 03, 2015 1:13 pm
Year and Trim: 1996 Bonneville S/SE
On my l67 swap I am using a gen 5 m90 with a northstar throttle body. I am looking at intercooling it and using a full height intercooler. Does anyone know if this will clear the hood? Or should I just use a short stack intercooler?
Thanks
Dave
INFO FOR CONVERTING SE TO SSE BODY HERE=>>http://www.pontiacbonnevilleclub.com/forum/detailing-appearance/topic39372.html
http://www.pontiacbonnevilleclub.com/forum/performance-brainstorming/topic43633.html
2002 Pro Stock Pontiac Firebird**GM 399 Splayed Valve Engine
1996 Pontiac Bonneville SE/SSE **100% Transformation from SE to SSE Complete**Lowered 2.00inches too**
PostPosted: Wed Jun 03, 2015 1:26 pm
Year and Trim: 2004 GTO
It might be close, can you mock it up with a piece of wood under the blower that's the same height as the full stack?
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:
Hi.
PostPosted: Wed Jun 03, 2015 5:41 pm
IIRC, Todd Allen had a full height intercooler on 8 Ball, with the Gen 3. It cleared except for the small threaded piece on the top of the fuel rail that holds down the sight shield.
PostPosted: Wed Jun 03, 2015 10:21 pm
^^That's on a 00+ though.
PostPosted: Thu Jun 04, 2015 12:02 am
Oops, that's right. I failed to remember we're dealing with a '96.
PostPosted: Thu Jun 04, 2015 11:37 am
Unfortunatly, the engine is on the stand right now. So I guess the plan moving forward will to be installing the engine without the intercooler and mocking it up to height once the engine is in.
Dave
PostPosted: Thu Jun 04, 2015 11:22 pm
I'd venture to guess that the 92-99 has more clearance than a 2000. My 2004 fits the GenV and full stack IC with no issues.
PostPosted: Fri Jun 05, 2015 9:29 am
Year and Trim: 2003 SSEi.
LOTS of Mods
An old member with a 97 SSEi ran a Gen V with a Full size IC with no cutting
PostPosted: Fri Jun 05, 2015 12:46 pm
I remember that car... It was a hoot to drive it too...
PostPosted: Fri Jun 05, 2015 4:40 pm
Year and Trim: 2000 SSEI
you could always lower the sub frame with spacers a tiny bit to gain some room as well as make sure you have a solid front mount so you dont have a lot of movement out of the motor..
Shane "RedZMonte"
2004 Z16 Z06: Virgin
There are no new unread posts for this topic. Eaton sc's
Sadden
Wed Jun 10, 2009 5:44 pm
Sadden View the latest post
There are no new unread posts for this topic. Intercooler
bobtaz13
Mon Dec 05, 2011 7:22 pm
jedwards83
Tue Jan 17, 2012 8:01 pm
There are no new unread posts for this topic. intercooler
deano55
11
3368
Sat Jan 19, 2013 12:39 am
deano55 View the latest post
deano55
Wed May 23, 2012 12:29 pm
yourgrandma View the latest post
