It is currently Mon Feb 17, 2020 9:08 pm
PostPosted: Sun May 10, 2015 9:17 pm
Year and Trim: 1996 Bonneville S/SE
I plan on swapping the '96 over from the 4T60 to a 4T65 that I sourced from a '98 Bonneville SE. I would really like to convert this transmission over to the HD version and use 3.39 Overall Gear Ratio. However I have a couple of questions.
1. Are all HD diffs a 3.29 Ratio Diff?
2. Do I need to swap the ring gear in the non-hd 4t65 at the same time as I swap the diff? Which Ring gear would I need to source.
I plan on installing the 4T65 HD upgrade kit from ZZP and their 7/8 chain kit too. I am just trying to make sure I don't miss anything during the rebuild.
Thanks
Dave
INFO FOR CONVERTING SE TO SSE BODY HERE=>>http://www.pontiacbonnevilleclub.com/forum/detailing-appearance/topic39372.html
http://www.pontiacbonnevilleclub.com/forum/performance-brainstorming/topic43633.html
2002 Pro Stock Pontiac Firebird**GM 399 Splayed Valve Engine
1996 Pontiac Bonneville SE/SSE **100% Transformation from SE to SSE Complete**Lowered 2.00inches too**
PostPosted: Mon May 11, 2015 11:16 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I can't recall exactly, but I thought you only need a ring gear change if you have a 4t60.
PostPosted: Tue May 12, 2015 8:17 pm
Thanks
If memory serves, a stock 2.86 ratio or 3.05 4T65E will have the 35 Drive and 35 Driven gears, The 4T65E HD uses a 37 Drive and 33 Driven for an overall 2.93 ratio( This is the 3.29 Diff )
If you use the 35 Drive and 35 Driven with the 3.29 HD Diff, HD diff cover and HD axle you will have an overall 3.29, I would get the ring gear just to have it, but iirc the ring gears between the 2.86, 3.05 and 3.29 should be the same.
PostPosted: Wed May 13, 2015 12:15 am
What exactly is in ZZP's upgrade kit? Be wary of them, they love to sell snake oil. The HD trans is in reality no stronger than the regular one.
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Wed May 13, 2015 9:11 am
Year and Trim: 2003 SSEi.
LOTS of Mods
to convert from a Non HD to a HD you need the following.
HD Diff (3.29 ratio they are all this way)
HD Diff Cover
Passenger Side SSEi axle
PCM Programming to accept the 3.29 ratio
I "think" the sun gear that is inside the Diff is a different size, and you will need a HD Diff Sun Gear
PostPosted: Wed May 13, 2015 12:04 pm
I should have said make sure that 3.29 HD diff has the sun gear..lol
HD 3.29 on the left and Light Duty 3.05 on the right..
There are no new unread posts for this topic. 96 SE Gen V Supercharging 4T65 Project
Speedster400
42
3218
Fri Jun 16, 2017 2:59 pm
There are no new unread posts for this topic. 4t65 option codes
Speedster400
Wed Dec 24, 2014 1:41 pm
mylittleblackbird View the latest post
There are no new unread posts for this topic. 4T65 TransGo shift kit installation
LeSabre in Buffalo
30
12530
Mon Aug 12, 2013 6:39 pm
xcbullet View the latest post
There are no new unread posts for this topic. HID conversion
Yoshicoby
22
2443
Thu Oct 30, 2008 8:05 pm
There are no new unread posts for this topic. ZZPerformance Supercharger conversion kit
machinistmatt
Thu Feb 19, 2015 9:39 pm
