It is currently Fri Jul 10, 2020 1:24 am
 Post subject: Suspension Help
PostPosted: Sun Aug 03, 2014 7:28 pm
Year and Trim: 2001 Pontiac Bonneville SSEI
I am looking for anyway to firm up my stock suspension on my 2001 Bonneville SSEI
Does anyone know of Strut braces, Sway Bars, End links, the whole works that are able to work?
All help is appreciated.
Blake Hunter
 Post subject: Re: Suspension Help
PostPosted: Sun Aug 03, 2014 10:23 pm
Year and Trim: 2001 SSEi
Just find an FE5 suspension from a Bonneville GXP. It bolts right on, and is a nice upgrade.
Of course, the trick is finding it. Also be aware that the front struts are apparently unavailable new. I was able to find all the above from a GXP with a claimed 70K miles. The GXP front struts were definitely more solid than the ones that came off, and the rears were better than the new KYBs I had put on the rear right after I got the car. I'm happy.
You can also use polyurethane pieces for the front & rear sway bars. I haven't, yet, but probably will in the future.
PostPosted: Mon Aug 04, 2014 1:11 am
So basically start looking for oe Bonnie gxp suspension parts. And that will give me an upgrade? Sounds simple enough
Blake Hunter
PostPosted: Mon Aug 04, 2014 8:58 am
Year and Trim: '02 SSEi
That's the simplest route. Poly endlinks are super easy as well. The sway bar mount.bushings aren't too difficult either.
PostPosted: Fri Aug 29, 2014 7:10 pm
Year and Trim: 2000 SSEI
energy suspension has universal links you can use.. search my posts and you find the part numbers.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Fri Sep 05, 2014 6:39 am
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
So, the sway bar from a gxp is thicker than the one on a ssei?
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
PostPosted: Fri Sep 05, 2014 7:48 pm
IIRC it's either thicker or solid versus hollow tube. It is definitely higher-rate.
PostPosted: Fri Sep 05, 2014 8:16 pm
IIRC it's both slighter thicker and solid vs hollow for the SLE/SSEi.
PostPosted: Sun Sep 07, 2014 10:10 pm
Where can I find llRC?
Blake Hunter
PostPosted: Sun Sep 07, 2014 11:07 pm
IIRC stands for if I remember correctly.
PostPosted: Sun Sep 07, 2014 11:24 pm
stands for what..?
Blake Hunter
PostPosted: Sun Sep 07, 2014 11:26 pm
IIRC = If I Recall Correctly.
GXP sway bar is the same diameter as the SSEi, but it is solid vs hollow. Mega weight and stiffness difference.
-Andrew-
PostPosted: Sun Sep 07, 2014 11:34 pm
oh jeez i feel dumb....
but yeah looking into gxp sway bars
Blake Hunter
There are no new unread posts for this topic. Suspension
Sadden
Tue Jun 29, 2010 12:30 pm
Sadden View the latest post
ijreed
Sun Aug 26, 2012 1:23 pm
ijreed View the latest post
There are no new unread posts for this topic. Air bag suspension
Haulin ssei54
12
2460
Thu May 03, 2012 5:41 pm
RogueSSEi View the latest post
Tazman3212
Wed May 08, 2013 9:30 am
95naSTA View the latest post
There are no new unread posts for this topic. suspension upgrades?
Adamus Prime
18
4096
Sun May 27, 2012 12:41 pm
goldfreaz View the latest post
