It is currently Tue Sep 25, 2018 11:48 am
PostPosted: Tue Jul 01, 2014 5:50 pm
Year and Trim: 1996 Bonneville S/SE
So this summer I plan on doing the upgrades required to convert the interior over from the SE to the SSE. I am also looking at maintaining the interior color combination and the current cloth style interior.
This summer will include:
Replacing/powerwashing the factory carpet. (Completed)
Replacing the factory windshield.(current one has a split in it) with the SSE style one for the HUD. (Completed)
Installing factory HUD (Completed)
Installing fully functional factory U50 Cluster (Completed)
Installing GM U85 8 speaker sound system (Completed)
Reworking speaker deck to work with U85 Speakers (Completed)
Replacing current seats with AL7s(reupholstered). (Completed)
Adding an auto-diming rear view mirror. (Completed)
Add Aux input to factory radio. (Completed)
Also looking at replacing the exhaust system. But this will depend on time.. (On Hold)
Stay tuned.....
Dave
INFO FOR CONVERTING SE TO SSE BODY HERE=>>http://www.pontiacbonnevilleclub.com/forum/detailing-appearance/topic39372.html
http://www.pontiacbonnevilleclub.com/forum/performance-brainstorming/topic43633.html
2002 Pro Stock Pontiac Firebird**GM 399 Splayed Valve Engine
1996 Pontiac Bonneville SE/SSE **100% Transformation from SE to SSE Complete**Lowered 2.00inches too**
Last edited by Speedster400 on Sun Aug 10, 2014 10:29 pm, edited 2 times in total.
PostPosted: Sun Jul 13, 2014 2:22 am
Updates.
I was able to find two '96 SSE(one red, one black) in the salvage yard and was able to source the following:
U85 rear deck speakers and door speakers from the black one. $25
U85 speaker grilles from the red car. $15
Chassis Wiring harness from red car. $55
U50 Cluster and Dash assembly from red car. $75
The dash and HUD panel that I was able to get ahold of was black. So I repainted it to match my interior combination.
While waiting for the paint to dry, I also was able to get the interior striped and the carpet power washed. I was amazed how clean the carpet came with the power washer.
One thing that I noted before moving forward on the this project was that the A/C did not work. I have a code stored in the HVAC module for a failed mix door actuator. I had my suspicions on what the failure was and sure enough, a gear was split in the actuator.ImageImage
Stay tuned, more will be coming shortly.....
Dave
PostPosted: Mon Aug 04, 2014 8:53 pm
Well, I was able to get the chassis harness installed this weekend. However, I ran into a minor problem. The harness that I was able to get out of the yard was missing all of the connectors for the front lights,fans,coolant level sensor etc. Somebody previously cut them off. However, I was able to find out that Vintage Parts still had a GM new one in stock. So made the purchase and I now have a GM-New chassis harness installed in the Bonneville. With the new chassis harness installed, I was able to install the dash and perform the initial power-up of the dash.
Which to my surprise, everything on the dash work 100% And the really awesome parts is that the HUD is 100% functional!!!
With the HUD functional, I have now removed the windshield (The original had a split in it due to rust under the glass) and added in the wiring to run the auto darkening mirror. While waiting for the glass to show up, I created a stand alone harness for the U85 rear speaker assemblies.
I also worked on reworking my rear deck panel so that the speaker housings would accept the larger speaker grilles.
New Speaker grilles.
Speaker Grilles now Painted to Match
Original Rear Deck
Reworked Speaker Deck
Old Vs New.
Stay Tuned
Dave
PostPosted: Mon Aug 04, 2014 11:16 pm
A NEW chassis harness? :eek2:
That's awesome. Not even kidding.
Nice progress.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
74 Yamaha DT175: brap brap, brap
PostPosted: Tue Aug 05, 2014 12:04 am
Nice! Great work on the harness. - BC
In Memory of Brad - 1/21/1977 .. 10/23/2013 ...... Aaron - 1977 .. 2017 ..... ....... B & B
PostPosted: Sun Aug 10, 2014 10:48 pm
Updates, Updates.
So for any of you who would like to take on a project like this, I have some additional information about the chassis harness. For a '96, you will be looking for GM P/N 12175719. However, last time I checked, vintage parts only has one more new GM one. But there may be more out there that are not in the system.
So in other news, I have just received my newly skinned AL7 Seats.
The Originals
And the new covers.
I was able to get the almost stand alone harness out of the black '96 that was in the yard. Total cost to get new seat covers made was around $450 a seat incase anyone else has similar ambitions.
During the weekend I was also able to swap the radio out for the 7-band version AND added an Aux port to the radio. The neat part I think is the fact that I can now get XM radio to play over the speakers in the car.
The last piece of these updates was the glass, the original one had a split in it and needed to be replaced. So, I had the the "HUD Shaded" version installed. The main difference that I noticed was that with the plain glass, the HUD appeared in "double vision" whereas with the new glass meant for the HUD, it is perfectly clear.
Dave
PostPosted: Sun Aug 10, 2014 11:05 pm
Not knocking the seats as they look great!, but you might have found really nice used seats for much less. Just an observation as I wouldn't mind having the seats in my '92 redone (if it was running to my satisfaction) as I have considered it. I am enjoying the thread. - BC
PostPosted: Sun Aug 10, 2014 11:09 pm
Nice progress.
Who did you go through to get the seats reskinned?
05 Suzuki DRZ400S
PostPosted: Mon Aug 11, 2014 9:41 am
Erickson auto trim for the seats.Out of menasha,wi.
Dave
PostPosted: Mon Sep 22, 2014 5:20 pm
Year and Trim: 98 Bonneville SE 3800 S2
great job so far!! My sister had them do the seats for her car after she wrecked it a few winters ago and the did one *dang* good job! Man you guys are way out classing me with these great works compared to my simple little stuff lol! keep it up!!
They call me...Snowflake
Mine:1998 Pontiac Bonneville SE 3800 II 250k miles (Bad engine)
MODS: all chrome lug nuts, ported UIM LIM, 180 T-stat
In Progress: Finished overhaul under the hood, & updated interior.
OURS(DD): 2003 Pontiac Grand Prix 3100SFI 165k miles MODS: custom lights both front and back
Hers: 04 Pontiac Aztec Base model. More to come later
PostPosted: Sat Oct 25, 2014 10:00 am
Year and Trim: 2002 Galaxy Silver SSEi
Hey great job with the car, even though I probably can't ever use this information, I find it awesome that you are doing such a transformation. Keep it up.
Tyler
2002 Galaxy Silver SSEi "Silver Shadow" 181, xxx miles- DD, tinted taillights, 10000k HID low beams, GXP strut brace, carbon fiber overlays, GXP door bezels and vents and Aeroforce Interceptor Gauge, cleared corners, drilled and slotted rotors, painted calipers, Intense Stage 1 Performance package, smoked door reflectors.
2001 Galaxy Silver SE 119, xxx miles- RIP
2007 White G6 Economy 96, xxx miles- Wife's car, carbon fiber inserts, tinted windows.
PostPosted: Sat Oct 25, 2014 1:37 pm
Very nice! I love the way the seats turned out. Thanks for sharing. - BC
There are no new unread posts for this topic. I'm Excited - Part II
PDXGTP
60
3678
Mon Aug 25, 2008 8:58 pm
PDXGTP View the latest post
There are no new unread posts for this topic. I'm Excited - Part III (or IV-Can't Remember Where We Were)
Echo SSEI
76
4796
Wed Jan 28, 2009 11:34 am
Echo SSEI View the latest post
There are no new unread posts for this topic. need part # for brake upgrade
alexcoqui
19
1977
Fri Jan 29, 2010 12:12 am
laxmangl View the latest post
There are no new unread posts for this topic. Need some verification on part numbers.
irish91983
Thu Mar 08, 2012 7:18 pm
irish91983 View the latest post
There are no new unread posts for this topic. GXP Brake part numbers
xxdabroxx
Thu Jun 04, 2015 6:02 pm
BBamm View the latest post
