It is currently Thu Feb 21, 2019 10:59 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Cadillac 3800 Swap?
PostPosted: Thu Jan 08, 2015 3:11 pm
Awesome that is was that simple/cheap. Looks 100% stock. Nice job.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Thu Jan 08, 2015 3:49 pm
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
This is really awesome! I am so glad you posted this! You are giving me terrible ideas!
So how did the wiring go? You said modded fuse box connector? Was there any mods to wiring or any issues?
What year did you use? Any year 00-05 should work as a donor correct? Or does the donor have to be the same year as the cadillac?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Thu Jan 08, 2015 7:55 pm
That is awesome!
PostPosted: Thu Jan 08, 2015 7:58 pm
Looks like some good work! Completely OEM.
PostPosted: Fri Jan 09, 2015 12:50 am
Year and Trim: 97 SE w/L67
Thanks everyone.
94silverSSEI, I had to change the insulator for the engine harness to match the Caddy
fuse box. One had the bolt in the insulator, the other one the nut that mounts it. I was
able to make the car run and drive after just switching the insulator(moving the wires).
There is wiring in the Caddy harness the Bonne harness doesn't have. ABS wiring mostly.
The ABS module is dead on the Caddy so I didn't bother.
PostPosted: Fri Jan 09, 2015 12:53 am
Oh, and I used a 2001 SSEi harness. I imagine '00-'03 would work.
PostPosted: Fri Jan 09, 2015 1:07 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I'm in the "That's friggin Awesome!" camp! Well done!
Runs:
Doesn't run:
PostPosted: Fri Jan 09, 2015 3:06 pm
68 w/400
94 SSEi
l67se wrote:
Thanks everyone.
So did you have to have a manual for each and actually repin the harness? I'm not sure exactly what you meant by "switching the insulator"? So the ABS won't work with this swap or you are unsure as your ABS was dead? I was very much interested in doing this swap into a 98-03 seville. But I was unsure of the wiring/electronical part. What year was your seville? Also is yours an SLS or STS?
I would prefer an STS but I know it has more electronics that could be come an issue?
Clay
PostPosted: Sat Jan 10, 2015 1:11 pm
My Caddy is a 2000. It's a SLS.
The wires for the fuse box side; I just moved them from the Bonne plastic insulator
to the Caddy insulator so I could mount the insulator into the bottom of the fuse box.
The wires went into the same slots that they came out of. I did have connector pinouts
for both cars that I pulled from alldata.
There were 4 wires for the ABS that ran from C101 to the ABS module on the Caddy that
the Bonne harness didn't have. I added those wires to the Bonne harness (can't remember
what they were for right now) but the Caddy ABS still didn't work. I had checked the power
and grounds to the Caddy ABS and they were good. I assumed the ABS module was dead and
didn't bother pursuing it. So I couldn't tell you for sure whether the ABS was dead already or
the swap somehow caused it.
My SLS is fairly loaded. The only options it doesn't have is the sunroof and rear park aid. I imagine
there wouldn't be anything over and above on a STS that might cause issues.
PostPosted: Sun Jan 11, 2015 3:29 pm
68 w/400
94 SSEi
Ok thanks for the help!
I happen to have an 05 Deville at the moment and I'm 99% sure it has bad headgaskets wonder how similar the seville and deville are? It's an extremely base deville. Has no options. I think it should swap no issue?
Clay
PostPosted: Mon Jan 12, 2015 9:23 am
During my junkyard runs for a breather that would fit the Seville and 3800, I found that the Deville was much closer in match to the Bonneville. A/C lines route the same so I don't think the condenser would need replaced. The accumulator is in the same place also. On the Seville, I had to move the accumulator(and use the Bonne accumulator) to the engine side of the fuse box to get the 3800 A/C lines to match up.
I just did a quick check on wiring connectors and it looks like the Deville has the same setup. Fuse box for one side of the engine harness and C101 for the other. Definitely looks doable with minimal issues. I imagine since it's closer to the Bonne setup, that the overflow tank and breather from the Bonne would work too.
I couldn't make the coolant overflow from the Bonne work for the Seville since it was on the passenger side and the way the fuse box and A/C lines routed on the Seville, there was no room for it. The overflow (driver side mounted) and breather from a Park Ave ('02 IIRC) fit perfectly.
I had to extend the magnasteer wiring on the Bonne harness because the Seville harness plugged in at the steering gear. The Bonne harness plugged in near the passenger side of the steering gear. I also remember having to do something with the passenger front ABS sensor connector but for the life of me, can't remember if the Bonne harness needed modifying or if it was just damaged there. You'll also have to do the "learn" for the Bonne PCM once it's in the Deville. Key on till the security light goes out on the dash (approx 10 minutes) cycle key off, back on twice more (30 min total time) to get the Deville to recognize it.
Basic parts list (off the top of my head)
Complete 3800 Bonne drivetrain including mounts and exhaust down pipe
Bonne 3800 radiator, radiator hoses and heater hoses
Bonne engine wiring harness and PCM
Bonne 3800 power steering hoses
Can't think of anything else you'll need at the moment.
I'll be happy to help any way I can if you decide to do the swap.
You can PM me for my email
PostPosted: Mon Jan 12, 2015 11:22 am
68 w/400
94 SSEi
Hmmm. Well I already have the 05 Deville which I originally bought for my grandmother but its too big and then was going to be a swap but I'm thinking this would be a fun project. Never put an engine in something it didn't come in.
Well I've run across an 03 Lesabre with low miles that was in a bad wreck. I know an L36 Deville would be a turd but its such low mileage on the lesabre, its hard to pass up.
I've cross-checked part number and it looks like most all suspension components are the same. I'm wondering if it might be easier just to swap the whole subframe out of the lesabre into the deville? So you used the Cadillac steering rack then?
Checked the radiator and condenser and they show different part numbers but they look VERY similar so I think I would be able to reuse the one from the Deville as the donor Lesabre is whacked pretty hard in the front.
oh yes, I'm very familiar with the 30 minute relearn. I can't even count the number of times I did that on the last Bonnie.
Thanks I really appreciate the help!
Clay
PostPosted: Mon Jan 12, 2015 6:51 pm
I would have to say, GOOD JOB! and agree with Matt. - BC
PostPosted: Thu May 28, 2015 7:02 pm
Year and Trim: 1964 Cadillac Deville Flower Hearse
Great post!! I run a small garage in the caribbean, one of my clients owns a funeral house and has a fleet of caddy's ranging from 1994 to 2004, this post just gave me a great project to work with him, he was excited to know that there is another option rather than the N*. With all the heat and at funeral speed they blow the gasket pretty quickly down here, next week im going for a swap like this one.
PostPosted: Fri May 29, 2015 4:21 pm
I can't believe I never saw this one after l67se posted. This is freaking cool.
PostPosted: Mon Aug 03, 2015 2:06 pm
I managed to do this swap and get the caddy running fine. So far everything seems allright. Minor details coming up but nothing important. Got 2 more caddys waiting for the outcomw of this one to do the same swap. Biggest headache was getting the passkey to work since the caddy had it override, nothing that some pcm reprogram couldn't solve
PostPosted: Thu May 19, 2016 8:51 pm
Year and Trim: 1999 Bonneville sse
I'm just starting on this swap using a 2001 Seville STS and a 1999 Bonneville parts car. Did you guys that did the swap use the 4t65 or the 4t80 trans? I have both and trying to decide the best route to go. I'll be using the Bonneville ECM and engine wiring harness. It looks like if I use the 4T65 I'll have to build mounts for the Caddy engine cradle?
PostPosted: Fri May 20, 2016 5:02 am
4T80 doesn't fit the 3800. Most of the stuff you need like the radiator, condenser, etc. needs to come from a '00 up Bonneville.
The 99 Bonne trans will need the side cover switched to an aluminum one so the side mount can be used.
You'll also have some wiring compatibility issues as the 99 trans uses an external P/N switch and the '00 up is internal.
I don't know if the 99 wiring harness will work without extensive modification since it doesn't have the C101 and fuse box connectors that match the Caddy.
This is what I can think of off the top of my head at the moment. It's still early and I haven't had a full cup of coffee yet..lol
PostPosted: Fri May 20, 2016 7:10 am
Wow, didn't realize the differences would be that much in just one year. I guess a trip to the boneyard is in order to find a wiring harness. I'm thinking I can make the radiator work. So the side cover mount on the trans is the one by the rack n pinion?
Thanks for the help!
PostPosted: Fri May 20, 2016 10:01 am
'05 STS-4
'97 LeSabre
The 4t80 can be used, just have to grind a few tabs on it, I can point you to more details if you're interested.
Runs:
Doesn't run:
There are no new unread posts for this topic. GXP 3800 Swap
Freejack
Fri Sep 08, 2017 12:47 am
Freejack View the latest post
There are no new unread posts for this topic. 3800 to northstar swap on 95 se
soundman9826
Mon Feb 05, 2018 12:25 pm
There are no new unread posts for this topic. Completing the swap - Supercharged 3800 into 1997 SSE
jafleisher
Mon Oct 25, 2010 9:28 pm
willwren View the latest post
There are no new unread posts for this topic. 3800 TO 3800 SUPERCHARGED
bonneowner
21
4741
Fri Aug 12, 2011 7:52 pm
bonneowner View the latest post
There are no new unread posts for this topic. n/a 3800 s2
bonnieslp
Wed Nov 19, 2008 3:14 am
bonnieslp View the latest post
