It is currently Tue Apr 16, 2024 7:53 pm
 Post subject: L32 bonneville
PostPosted: Fri Jan 24, 2014 10:42 pm
Looking to replace my L67..Few questions..
What do i need to know about this swap??
Any modifications.. needed parts..other upgrades?
Options in finding a good L32
Any help is greatly appreciated.. my motor had a oil circulation problem Thursday morning, maybe a clogged oil filter. Was making a hell of a noise..did an oil change..its better.. but still alot of noise..no power
Thanks for any help
240k, Cleared Corners, Silverstars, Yellow 893 fogs, LED Marker,
Reverse & interior bulbs, L32, Triple Edge
transmission, Intense FWI, N*, GXP Brake & Swaybar Swap, Pacesetters
 Post subject: Re: L32 bonneville
PostPosted: Fri Jan 24, 2014 11:23 pm
What do i need to know about this swap?? Not sure what you are asking here, it is a typical swap. Can you be more specific at what you are looking for?
Any modifications.. needed parts..other upgrades? It depends on your budget and how far you want to go. There is SC porting, LIM port matching, cams, headers etc. At a minimum, you will want to use the metal LIM gaskets.
Options in finding a good L32. Look for Grand Prix motors, they wiil swap and are more plentiful. The L32 will work, just search for VIN 4 and 2006 Grand Prix. The biggest difference will be the oil pans.
PostPosted: Fri Jan 24, 2014 11:47 pm
Saw this one
http://www.lowmileageparts.com/2006-PON ... uMyw0xOmSx
Wasn't sure mainly on the plug and play of it..my factory computer will work with it?
PostPosted: Sat Jan 25, 2014 12:19 am
Year and Trim: '02 SSEi
Youll want the bonneville accessories, oil pan, fuel rails/injectors and a TB adaptor to run either an L67 TB or an LS1/N* throttle body. The vacuum setup is a bit different but as long as youre not doing anything extra like intercooling and whatnot, ytou should be fine with the stock vac harness.
PostPosted: Sat Jan 25, 2014 12:48 am
Thanks..good to know..would love to do fuel rails..easy to add?? Any idea pricing??
Oil pan off my L67 can be swapped.. will get new injectors
Not sure about TB..any suggestions?
PostPosted: Sat Jan 25, 2014 11:47 am
Year and Trim: 2003 SSEi.
LOTS of Mods
lets just slow down here.
as randy said, you will have to reuse all of your Bonneville Accessories.
oil pan
oil filter adapter
Passenger Side engine mount
Bonneville Tensioner Bracket
L67 Fuel rail
L67 Injectors
you will need a Gen V to TB adapter I would recommend the Northstar because it matches the ID of the SC inlet. You will also need a MAF to go along with this and the LQ4 is the best
you can reuse the EVAP off the Gen V and plug right in your stock connector
you will have to remove the front dog bones off of the W body engine
PostPosted: Sat Jan 25, 2014 12:28 pm
Thank you guys for the advice/experience..
I just need to find a motor..N*TB..LQ4..injectors..fuel rails. Any ideas on sourcing these parts?
Haven't been able to contact Billboost..my mechanic.
PostPosted: Sat Jan 25, 2014 1:14 pm
LOTS of Mods
use your STOCK fuel rails and Injectors
I can talk to Bill for you
PostPosted: Sat Jan 25, 2014 1:56 pm
If you can get in touch with Bill... that'd be great!!
I've wanted aftermarket fuel rails..looks cleaner..see a painted supercharger.. etc.
PostPosted: Sun Jan 26, 2014 6:50 pm
Any luck getting in touch with Bill?
There are no new unread posts for this topic. V8 in my 96 bonneville sse
theirongiant99
Fri Jun 16, 2017 2:51 pm
There are no new unread posts for this topic. 03 Bonneville SE mod help?
Dannyg420
Wed Mar 20, 2013 12:52 am
Dannyg420 View the latest post
There are no new unread posts for this topic. Lowering 95 bonneville
95 bonny
Thu Aug 28, 2014 9:39 pm
95naSTA View the latest post
There are no new unread posts for this topic. wanting to SC my bonneville sle. how to?
02BonnevilleSLE
Fri Apr 30, 2010 2:03 pm
olblueeyesbonne View the latest post
There are no new unread posts for this topic. bonneville mods
rjgordon
Wed Dec 10, 2014 11:47 pm
rjgordon View the latest post
