It is currently Mon Feb 18, 2019 9:10 pm
PostPosted: Wed Aug 06, 2008 8:17 pm
Year and Trim: Loaded 2005 GP GTP
Just wondering if anyone has done it or seen one? Would it even fit? How hard to do?
Just weighing the options for the future. :-$
Almost 79k miles
Mods....
Homemade FWI
Autolite 606 plugs, Autolite wires, new PVC and APC cone filter at 66k miles
PostPosted: Wed Aug 06, 2008 8:30 pm
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
2013 Audi A4 6MT
Pretty dang hard, but if you had unlimited resource (i.e. money, time, know-how), you might be able to do it.... but why? That engine has no modification potential, it's not as fast or as easy as an L67 and it gets worse gas mileage...
Year and Trim: '92 Roadmaster
9 words. Not worth the cost and modification it would take.
That is all. :lol:
2009 Escape Limited - 4WD - V6 - 108k
1992 Roadmaster - L05 V8 - 110k - Minty
PostPosted: Wed Aug 06, 2008 8:39 pm
Aye Aye Cap'n!!
Just a thought. Guess not a very good one.
Almost 79k miles
Mods....
Homemade FWI
PostPosted: Wed Aug 06, 2008 8:40 pm
An L67 swap would net you better fuel economy, more power, and far greater reliability, with greater ease of installation than the Northstar.
PostPosted: Wed Aug 06, 2008 8:43 pm
How much would one of those L67's cost for a complete motor/trans combo and all electonics?
Probably be easier for me to get a G8GT instead of doing the swap! (easier to tell the wife what I'm gonna do, I mean)
Almost 79k miles
Mods....
Homemade FWI
PostPosted: Wed Aug 06, 2008 8:45 pm
Year and Trim: ____
Not hard at all if you know what you're doing. Not that costly either. But probably easier to just get an SSEi, that way you have the engine and allll of the features.
John
PostPosted: Thu Aug 07, 2008 12:34 am
Year and Trim: 1988 and 1987 Buick Lesabre T-Type
Whats your skill level? If you can weld and measure things and can understand wiring diagrams completely then the swap probably wouldnt be too hard. I am not a big fan of the northstar but i would consider swapping one in my '88 lesabre if the price was right for a good engine and trans. And it would require the same amount of work that it would take for you to do it.
~~~Freddy~~~ Wyotech Graduate, Future RCSAMS student
Pandora 1988 Lesabre T-Type 259000 miles
Darlington 1987 Lesabre T-Type 115000 miles
Cream Puff 1988 Lesabre T-Type 194500 miles
PostPosted: Thu Aug 07, 2008 7:06 am
Year and Trim: 00 Regal
To answer your orignal question, it doesn't seem as though anyone honestly knows.
No one has tried it before. It would probably require mounts etc to be fabbed. Depending on your available tools and skill level this might be a low cost project that takes nothing but time and a bit of effort. Someone stuffed a 4T80 into the car with nothing but the items normally found in his garage. His garage isnt' the norm though.
97 Ei
97 GS
98 GS
PostPosted: Thu Aug 07, 2008 4:42 pm
Year and Trim: 1998 Pontiac Grand Prix GTP
Actually, someone put a northstar in a Grand Prix in Minnisota.
Hard, I would imagine.
Expensive, sure, of course.
Can it be done, of course...
IMHO, it would be a much better mod to just go the route of the L67 top-swap.
if you currently have the L36, keep the stock bottom end, do the L67 top swap, its much cheaper, easy to do for $1,000.00
The best part of the conversion from L36 to L67 top swap is that the L36 has lighter pistons & connecting rods, it also has higher compression.
Best 60' = 1.716
Best ET = 12.186
Best MPH = 112.98
PostPosted: Thu Aug 07, 2008 10:06 pm
Year and Trim: buick regal ls 2002
NEBF07 ONBF07 ONBF08
did you ever look under the hood of a gxp that engine is so thight in there and there nothing to mod them and very expensive to fix
i say go L67 the only thing better whit the 4.6 is the sound of the v8
buick regal ls 2002 L36 Buick regal 1983 357 sbc ,2003 Buick park avenue ultra
modkn4750,CAI,er rockers,powerlog,2.5 downpipe,high flow cat,dynomax muffler,hv3,ported LIM,autolite 104,waterpump u/d pulley,180 stat,aeroforce scan gauge,etx mag 17x7.5,245-45-17 flaken ze 912,
pb 14.97@92.77mph 2007 pb 2008 95.45 mph
don
There are no new unread posts for this topic. L67 or northstar TB ?
2 loud
Tue Apr 19, 2016 9:08 pm
95naSTA View the latest post
There are no new unread posts for this topic. v8 northstar
99bonnie
19
1296
Sat Feb 07, 2009 10:49 am
silverws6ta View the latest post
There are no new unread posts for this topic. northstar swap?
motopsyco
Mon Dec 09, 2013 2:05 pm
repinS View the latest post
There are no new unread posts for this topic. SUPERCHARGE the NORTHSTAR V8?
mccinima
Fri Feb 18, 2011 1:14 am
BonneMe View the latest post
There are no new unread posts for this topic. Northstar Throttle body
bobtaz13
Wed Dec 21, 2011 8:55 am
Larz01 View the latest post
Users browsing this forum: Google [Bot] and 3 guests
