It is currently Fri Apr 10, 2020 9:10 am
 Post subject: Suspension
PostPosted: Tue Aug 21, 2012 5:51 pm
Year and Trim: 1996 Pontiac Bonneville SSEI
I was wondering what suspension i could get to be on par if not better than the original struts on my 1996 pontiac bonneville ssei.
 Post subject: Re: Suspension
PostPosted: Tue Aug 21, 2012 8:45 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
My opinion: OEM or KYB GR-2
PostPosted: Wed Aug 22, 2012 8:58 am
Hands down Monro-matic plus shocks. Don, jr's3800, pointed me in this direction after not being impressed with the GR-2s.
I've only run them in the rears though since I went a different/hybrid direction with the fronts.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Wed Aug 22, 2012 4:51 pm
What about in the front? I have the Monroe quick struts in the front and the back of my car and its kind of bouncy. Also what is the price range on those if you don't mind me asking?
PostPosted: Wed Aug 22, 2012 5:01 pm
I went with a KYB-AGX front strut for a W-body (Grand Prix/Regal/etc.) for the front because GR-2s couldn't keep up with my old 2" drop. It's not a direct swap and it gets pricey. The link in my sig has more info.
Don has suggested the Monro-matic plus struts for front and rear as an OEM replacement. Rock Auto has them if you want to look up the price.
05 Suzuki DRZ400S
PostPosted: Wed Aug 22, 2012 5:16 pm
Will the struts you named stiffen the ride up quite a bit versus the quick struts? It bounces everywhere. Also is there any upgrades i can do for good cornering.
PostPosted: Wed Aug 22, 2012 6:00 pm
'05 STS-4
'97 LeSabre
I thought all SSEi models had the firmest suspension options already, so going stiffer will be more difficult and probably require some custom work. But bigger sway bars, larger diameter rims, wider tires, strut tower braces and other structural braces will all help cornering. As well, replacing suspension bushings, strut mounts, etc...
But, I only every had OEM F41, FE1, FE2, Monroe Gasmatic, and KYB struts to compare side-by-side and haven't played with anything else (was happy that a '86 LeSabre could keep to the corners like my brothers' W-body).
PostPosted: Wed Aug 22, 2012 10:48 pm
I don't have the factory struts anymore. I have the Monroe quits struts on the front and rear. I was asking will the struts 95naSTA named be stiffer then the ones I have.
PostPosted: Thu Aug 23, 2012 8:53 am
Yes, they should.
Addco makes sway bars for our cars: http://www.swaybars.com/searchresults.a ... LLE%20(FWD)
Those year ranges on their site are a little wonky though..
05 Suzuki DRZ400S
PostPosted: Sun Aug 26, 2012 1:23 pm
Would polyurethane end links in the rear help with understeer.
There are no new unread posts for this topic. Suspension Help
fromtheashes
12
1504
Sun Sep 07, 2014 11:34 pm
fromtheashes View the latest post
Sadden
Tue Jun 29, 2010 12:30 pm
Sadden View the latest post
There are no new unread posts for this topic. Air bag suspension
Haulin ssei54
12
2367
Thu May 03, 2012 5:41 pm
RogueSSEi View the latest post
Tazman3212
Wed May 08, 2013 9:30 am
95naSTA View the latest post
There are no new unread posts for this topic. suspension upgrades?
Adamus Prime
18
3998
Sun May 27, 2012 12:41 pm
goldfreaz View the latest post
