It is currently Tue Apr 07, 2020 4:01 pm
 Post subject: Air bag suspension
PostPosted: Tue May 01, 2012 10:35 pm
Year and Trim: 2003 ssei
Im not sure if any other members have done air bag suspension on a bonneville but I was curious if I did go that route would I be sacrificing any of the ride quality? I just want something that can drop the car about an inch to 2 inches all around for better handling and my opinion a cleaner look but I just wanted to get some feed back on this
 Post subject: Re: Air bag suspension
PostPosted: Tue May 01, 2012 10:44 pm
Year and Trim: 2004 GXP
I too am interested in this but know nothing about it..
Seth
RogueSSEi wrote:
Bet she'll stop on a dime and give you 3 pennies back!
PostPosted: Tue May 01, 2012 10:52 pm
I just looked around at some kits and they vary from about 800 bucks to 3,000 haha but if I got that there is no way I could put it in myself
PostPosted: Tue May 01, 2012 11:30 pm
Too much custom fabrication? Are they made for bonnevilles?
Seth
PostPosted: Wed May 02, 2012 12:37 am
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Pretty sure there are no kits made for Bonnevilles. Im sure there would be some on this forum.
PostPosted: Thu May 03, 2012 12:46 pm
I would too like to do the same...... fabrication, fabrication, fabrication..... not good for a daily driver lol
PostPosted: Thu May 03, 2012 2:02 pm
It'll ride like sht at a lower ride height, have issues with moisture in the lines with sub freezing temps, and will involve fabrication.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Thu May 03, 2012 2:26 pm
I would only want it lowered when I'm parked and only an inch or 2, this is the site that I found some on.
http://www.airbagit.com/product-p/fbx-f-pon-08.htm
How do cars handle when they are pumped up? Lots of body roll?
Seth
PostPosted: Thu May 03, 2012 3:01 pm
You wanting to hall balls and drive it like it's on rails with air struts? I had a 89 B2200 bagged that didn't have any problems, but it wasn't built for speed, just dragging frame (well trailer hitch balls), but that's comparing apples to oranges, the ride with a good air management I wouldn't say it would, assuming you have on board gauges to get you to the right and smooth ride height, you shouldn't have any problems, maybe a little stiff if aired' up all the way and floatie if not aired' to the right psi.
PostPosted: Thu May 03, 2012 3:03 pm
Your air pressure becomes your spring rate. It's possible to meet and exceed your current spring rate with the right pressure. The problem with that is it might net you a higher ride height and you can only be aligned for one ride height.
05 Suzuki DRZ400S
PostPosted: Thu May 03, 2012 4:22 pm
Sounds like I might like it..
Seth
PostPosted: Thu May 03, 2012 4:39 pm
Also what would I do for the rear air shocks? Can the rear ones be deflated (and not driven on) without hurting them? Anyone know the lowest pressure that the rear air shocks can still be driven on?
Seth
Last edited by sethjamesrimrodt on Thu May 03, 2012 4:40 pm, edited 1 time in total.
PostPosted: Thu May 03, 2012 5:41 pm
I would use these and fabricate them to your rear specs. http://store.gaugemagazine.com/sleave-b ... short.aspx
I wouldn't risk the OE as an aftermarket adjustable air suspension, IIRC there is a type of piston in the rear air sleeve that is use for absorbtion for different road conditions, this could damage the strut and leave you limping and dragging a$$ home if they blow and give out.
There are no new unread posts for this topic. Suspension Help
fromtheashes
12
1502
Sun Sep 07, 2014 11:34 pm
fromtheashes View the latest post
Sadden
Tue Jun 29, 2010 12:30 pm
Sadden View the latest post
ijreed
Sun Aug 26, 2012 1:23 pm
ijreed View the latest post
Tazman3212
Wed May 08, 2013 9:30 am
95naSTA View the latest post
There are no new unread posts for this topic. suspension upgrades?
Adamus Prime
18
3998
Sun May 27, 2012 12:41 pm
goldfreaz View the latest post
