It is currently Tue Jan 22, 2019 4:26 am
 Post subject: series 2 3800
PostPosted: Sun Jan 15, 2012 2:38 pm
Year and Trim: 96 SE
87 LE
just got ahold of a 2004 3800 upper end heads lim mainfolds upper intake injectors and fuel rail im intrested in how much of this will be usefull to me on my 99 what works and what wont and will i gain anything if i swap if possible any info will be very usefull i got the parts for free so im not out anything i will just sell the stuff
 Post subject: Re: series 2 3800
PostPosted: Sun Jan 15, 2012 4:50 pm
Please try to use punctuation and proper sentence structure. Your post is pretty frustrating to read.
It will gain you pretty much nothing. You should replace your upper intake manifold with a Dorman or APN, and replace your lower intake gaskets with the new aluminum framed design before those inferior parts cause you a motor failure. It's very common, and every L36 engine like yours needs to do this and get rid of the DEX-cool.
www.dex-cool.net
PostPosted: Sun Jan 15, 2012 8:25 pm
:stupid:
It's not worth the additional cost to add the L26 UIM (only part that's different/somewhat usable) as it will cost you more to buy the adapters and other parts to make it work than it will to buy the upgraded manifold that will actually fix the weak point in your car.
PostPosted: Mon Jan 16, 2012 8:40 pm
87 LE
thank you 00beast for a straight answer i appreciate it greatly so the only diffrence is basically the upper intake? i mainly wanted the heads and lower intake manifold and exhaust manifolds so i can pnp
PostPosted: Tue Jan 17, 2012 12:54 am
They're all the same, but the LIM is a better casting, and the L36 leaves a lot to be desired.
There's really no need to port the heads, it's too much hassle to swap them for the little gain you'd get. You'll be much better off with valvetrain mods.
You need to have the front exhaust manifold welded before you can P&P it.
PostPosted: Tue Jan 17, 2012 11:23 am
Unless you're going with a cam or rockers, porting the heads may actually hurt performance rather than help.
There are no new unread posts for this topic. How to Mod a 3800 series 2 N/A?
Night Crawler
18
8668
Sun Aug 02, 2009 12:14 pm
There are no new unread posts for this topic. new guy injector questions 3800 series II
carl
17
5158
Tue Nov 25, 2008 7:26 am
carl View the latest post
There are no new unread posts for this topic. Changing Spark Plugs & Wires - 3800 Series II Supercharged
Brae
12
7055
Sun Sep 15, 2013 9:55 pm
There are no new unread posts for this topic. 3800 TO 3800 SUPERCHARGED
bonneowner
21
4708
Fri Aug 12, 2011 7:52 pm
bonneowner View the latest post
There are no new unread posts for this topic. series III N/A
swampthing
18
1365
Wed Dec 10, 2008 11:00 pm
cron
