It is currently Thu May 23, 2019 3:18 pm
 Post subject: Dual Exhaust
PostPosted: Fri Dec 16, 2011 8:13 pm
Year and Trim: 2001 Bonneville SE
I have been doing some research on y pipes since my bonnie only is a single exhaust and i think i can use a y pipe to create a true dual exhaust. i have a glasspack in place of the factory resonator so i need to know where i can install a y pipe after it. it sounds like a v8 as it is now so i also wanna know what effect it will have on the sound. also any info on gains/losses in performance would be appreciated.
Morgan
04 gxp bone stock internals. Touchscreen dash with heavily upgraded sounds system.
 Post subject: Re: Dual Exhaust
PostPosted: Sat Dec 17, 2011 10:13 am
1. You will gain nothing from it other than a lighter wallet. The only components that may improve performance are the downpipe and cat on your car. As much as you think it sounds like a V8, to the trained ear (a good many of us) it'll sound like a V6 with an aftermarket exhaust. You cannot make a V6 sound like a V8 regardless of exhaust type.
2. The stock SSEi exhaust from your year has a Y exhaust. Go get a setup from the wrecker.
3. Putting a Y in isn't true dual exhaust. It's simply dual outlets. True dual exhaust has independent exhaust all the way from the heads to the tips.
There are no new unread posts for this topic. SE: Single exhaust to Dual exhaust conversion: How-to
Bugsi
Sat Dec 24, 2016 4:58 pm
mybonnelou View the latest post
There are no new unread posts for this topic. Dual Exhaust
2002BonnevilleSE
11
1940
Sat Nov 13, 2010 2:07 pm
smokeysan View the latest post
There are no new unread posts for this topic. True Dual Exhaust :)
voller1410
23
4651
Sat Dec 17, 2011 3:57 pm
voller1410 View the latest post
There are no new unread posts for this topic. dual exhaust and mufflers
psburtis
11
3830
Mon May 26, 2008 9:21 pm
Bugsi View the latest post
There are no new unread posts for this topic. Help with Dual alternator kit
CDouble
22
5556
Thu Jan 19, 2012 11:49 pm
willwren View the latest post
