It is currently Thu Jul 18, 2019 4:00 pm
 Post subject: Intercooler
PostPosted: Sun Dec 04, 2011 5:47 am
Year and Trim: 2001 SSEi
1991 SE
Who runs what? I have a ssic but want more. I just don't think i have the hood space for much more.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
 Post subject: Re: Intercooler
PostPosted: Sun Dec 04, 2011 10:16 am
Year and Trim: '02 SSEi
I think the 2.25" core fits fine uner out hood. To be sur just use some plumbers dope or modeling clay on top of the blower ro see how much room there is.
In the meantime, gimme your ssic!
PostPosted: Mon Dec 05, 2011 2:14 am
1991 SE
With the Gen V there does not look like there is room. There is about 1/2 inch of clearance now.
PostPosted: Mon Dec 05, 2011 2:18 am
There are very few people on this forum that run IC's, and even fewer who post regularly (I personally don't know of anyone really who posts often on here). I think if you're out of hood clearance you're kind of stuck with what you have or another custom setup that doesn't go any further up.
PostPosted: Mon Dec 05, 2011 11:16 am
I don't recall the GenV being any taller, and I've rebuilt a few. The Gen3 fuel rail fits it fine. That should be the indicator. Get some Play-Doh and find out how much room you have left. And find out lust how much vertical height that core requires, depending on the IC design, it may not be the same as the thickness of the core depending on how it's mounted in the IC plates.
PostPosted: Mon Dec 05, 2011 1:16 pm
1991 SE
I just looked at it again and it looks like there is just enough clearance above the supercharges, but not above the TB and the TB adapter. Would a N* tb work better?
PostPosted: Mon Dec 05, 2011 3:46 pm
IIRC ZZP makes a turndown for the GTP's with the Gen V.
PostPosted: Mon Dec 05, 2011 7:22 pm
Year and Trim: 2000 SSEI
how large is the aftercooler? may be a worth while upgrade to add a larger aftercooler and a higher volume pump for your existing IC if hood clearance is an issue. the SC cobalt guys run mustang SVT cobra aftercoolers as a cheap upgrade. just a thought
Shane
Shane "RedZMonte"
2004 Z16 Z06: Virgin
There are no new unread posts for this topic. intercooler
deano55
Wed May 23, 2012 12:29 pm
yourgrandma View the latest post
deano55
11
1920
Sat Jan 19, 2013 12:39 am
deano55 View the latest post
There are no new unread posts for this topic. Intercooler
jedwards83
Tue Jan 17, 2012 8:01 pm
There are no new unread posts for this topic. SS Intercooler or Headers?
redzmonte
Thu Jun 05, 2014 3:02 pm
There are no new unread posts for this topic. icebox or intercooler??
turbo ssei
Wed Jan 21, 2009 1:02 pm
willwren View the latest post
