It is currently Mon Dec 09, 2019 8:30 pm
 Post subject: Turbo on a 95 L67
PostPosted: Wed Nov 30, 2011 5:50 am
Year and Trim: 1987 Pontiac Fiero GT
95 3800 S/C 97 4T60E
I have a 95 Riviera L67 in my 87 Fiero. Several people in the Fiero world have had amazing results from turbo Series 2 engines. I would like to ditch my s/c and run an NA intake. I would also be intercooling the system.
What are the power limitations of a Series 1? Fieros with turbo Series 2 engines are getting north of 450whp.
 Post subject: Re: Turbo on a 95 L67
PostPosted: Wed Nov 30, 2011 8:22 am
That's a very interesting question best answered by the differences between the motors.
The Series 1 has heavier internals and doesn't rev out as high in each gear. It's more of a torque motor. You won't gain the same net horsepower mod for mod, but will gain more torque than the Series 2 mod for mod. In a light car like a fiero, this could prove difficult to launch and drive.
If you go that route, I'd be looking at a larger turbo to spool later to save your tires. Remove the nosedrive and rotors, and machine a blockoff plate for that end of the blower to use as your housing, not an NA intake. The only NA intake system that will fit your block and heads is an L27, and it's far too restricted with a tiny little throttle body. Your current throttle plate is already larger than that of the Series 2 L67, making your M62 housing and stock TB more ideal for an intake.
Series 1 L67's are probably (in general) a bit stronger than the S2 L67 in terms of stoutness and durability. You're just not going to get 450hp if you copy the S2 car that achieved that same goal. Probably 400-425 mod-for-mod. You will have more torque though, peaking at a lower RPM and staying flatter across the curve than the same S2.
EDIT:
I just saw your profile. You'd be best served getting a better trans than that 4T60. You'll need something stouter. Why didn't you stick with the HD the L67 was originally bolted to? I'm assuming you changed your shift points and gear ratios?
PostPosted: Wed Nov 30, 2011 10:38 am
The 95 Rivi trans is a non-hd 4T60
PostPosted: Wed Nov 30, 2011 11:32 am
Not true. If it came under the L67, it's actually a 2.97 ratio HD trans, by use of a 3.33 ratio differential which is quite a bit more beefy than the standard 4T60's diff, and larger diameter axles. While not 'tagged' or otherwise identified as an HD, it was in fact so. The axle ratio is the giveaway clue.
Non-supercharged got the 3.05 axle ratio just like the H-bodies on this Forum, and the L67 equipped 95 Rivieras got the 2.97 ratio, just like both the 93 and 95 L67's that I own (in H bodies).
If you didn't account for this, and you're using the Riv PCM in stock tune, your shift points are wrong for that 97 4T60E, which is very likely a 3.06 ratio.
PostPosted: Wed Nov 30, 2011 11:45 am
Ryan Glick did my tune and did account for the ratio change. The trans is from a 97 3x00 Grand Am. The Rivi trans was shot and the GA trans was free.
PostPosted: Wed Nov 30, 2011 11:56 am
Ok just to make a note here.... 95 was a freak year for a lot of different things in GM....
Do you still have that 95 Riv SC trans? 95 was an odd ball year, the 95 SC Bonnevilles got the 2.97 ratio trans using a 3.33 diff...
The 95 Riv if it had the original trans got the 2.93 overall ratio using a 3.29 HD Diff, but this diff is the only year to have a reverse fine pitch... It will only work in that trans and no other due to the ring gear... in 96 they changed the pitch again and then left it alone...lol...
If you do have that 95 Riv trans it should have the one off 3.29 HD Diff... This was the only car i know of to have this set up until 96 when the other Supercharged H and C bodies went to it...
PostPosted: Wed Nov 30, 2011 1:14 pm
Don, I'm finding conflicting info on that. I'm seeing 2.97 ratio for the 95 Riv.
In either case, the original Riv trans was stronger than any non-HD 60 would be, especially if your plans include a turbo and the 400hp range.
PostPosted: Wed Nov 30, 2011 3:19 pm
I really need to find time to get better pics together... It seems what GM said they did and what they really did is not exactly correct...
The G body, NA 3800 used the 3.05 Diff, and the SC G body used the 3.29 diff for 1995( both of these being reverse fine pitch).. The 95 C and H body used the 3.33 diff for SC and 2.84 and or 3.06 for the NA( Regular pitch )...
1996 all of the SC C, H and G bodies all used the 3.29 Diff( fine pitch )
Its really screwed up how GM did all of this...
But here is the problem... There were regular pitch Diffs( 2.84, 3.06 and 3.33 ), then you had the Reverse fine pitch 1995 only 2.86, 3.05 and 3.29...
Then in 96 it was Regular fine pitch 2.86, 3.05 and 3.29... But the 96 fine pitch will not swap for a 95 reverse fine pitch or the other way around...
Now from what I can gather, the 2.84, 3.06 and 3.33 stayed a regular pitch and the last year for the regular pitch was 1997... 98+ is all fine pitch...
Only reason I have learned or had to learn this was due to the issues I was having finding the correct diff I was looking for.. GM really mixed it all up on this one...lol
The reason I was diving into his trans is that if he has this Riv Trans, he can also upgrade to the newer ring gear and run the 98+ 3.29 diff, and if it ever breaks he would have an easier time sourcing another... The 95 Riv trans was very one off..
PostPosted: Wed Nov 30, 2011 3:22 pm
:stupid:
I'm trusting Don w/ this one, LOL.
PostPosted: Fri Dec 02, 2011 6:46 pm
Location: Galloway, Ohio IDDVI, MWBF05, NEBF06, CEBF06, ONBF06, NEBF07, ONBF07
Year and Trim: 1998 Buick Park Avenue Ultra
Honestly, if I were building an L67 Fiero, Series 1 or Series 2, I'd drop the auto and put in a stick, either a Getrag 5spd, or the 6spd from the G6.
Fieros with big power are pretty twitchy in the corners, and a badly-timed shift from an auto could cause you serious grief. Unless you're only going to use this thing for commuting and drag-racing, manual is the way to go.
~Brian -- 98 Park Avenue Ultra
Mods: Too *dang* many...Click the siggy...
13.87 @ 101.40mph, Kil-Kare Raceway, 10/15/09
PostPosted: Fri Dec 02, 2011 7:21 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
I say manual is the ONLY way to go in a lil fire chicken. Much more driver input available and lighter.
PostPosted: Fri Dec 02, 2011 9:20 pm
Year and Trim: 06 Grand Prix LS4
Not to mention just plain cooler...
*Chris*
15 Impreza 2.0i Premium/97 F-150 XLT 4.6L 4x4
Previous, 07 GP SE, 06 GP GXP, 97 SSE 40th, 96 LeSabre Custom, 93 SLE, 90 LeSabre Custom
PostPosted: Fri Dec 02, 2011 10:24 pm
In any case, the non-HD transmission is a bad formula for success if you're considering a Turbo. Regardless of FDR. You have the wrong transmission, plain and simple.
PostPosted: Sat Dec 03, 2011 9:53 pm
In the Fiero world, 5 speeds are generally slower and pretty fragile in high hp Fieros.
First gear is basically useless in the Isuzu and Getrag 5 speeds with higher-torque engines,.
There are no new unread posts for this topic. have to ask...... (turbo)
99bonnieSE
Sun May 31, 2009 12:33 pm
99bonnieSE View the latest post
There are no new unread posts for this topic. ZZP Z7 Turbo Kit
comatoast
Fri Nov 12, 2010 9:08 pm
There are no new unread posts for this topic. turbo vs supercharged
02ssei
26
5022
Thu Oct 06, 2011 10:22 am
repinS View the latest post
There are no new unread posts for this topic. Cartuning turbo kit?
Summerson1
Sat Aug 25, 2012 8:57 am
yourgrandma View the latest post
There are no new unread posts for this topic. Supercharger AND Turbo?!
Sadden
63
4063
Mon Jun 22, 2009 8:14 pm
BonneMe View the latest post
