It is currently Fri Jul 19, 2019 11:37 am
PostPosted: Wed Feb 16, 2011 8:09 pm
ive got a 2005 GXP with the northstar v8 in it. is there going to be any chance i could slap a super on it? ive already gotten better plugs n wires n wut not n im tired of doing little things. i want to hear that supercharger wine.
PostPosted: Wed Feb 16, 2011 9:33 pm
Your problem (and the primary reason everyone will say NO) is that there is no PCM support for the GXP. You won't be able to tune for it.
PostPosted: Wed Feb 16, 2011 9:36 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Tuning the PCM is the hurdle that is the tough thing to get past.
PostPosted: Thu Feb 17, 2011 12:34 am
Wanna hear S/C whine? Get an SSEi or an STS-V.
PostPosted: Thu Feb 17, 2011 9:41 am
Year and Trim: '02 SSEi
Something like a megasquirt or other standalone engine management system would be all you could do, and then you'd have to use a nonelectronic trans I would think.
PostPosted: Thu Feb 17, 2011 4:05 pm
Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE
http://www.tciauto.com/Products/TC-%27E ... %27-0.aspx
not sure if it would work with the 4t65, but you could ask. Looks like it'd be a high dollar operation to add a blower if you are using a standalone engine management and standalone trans controller.
I have a Bonneville, it's white and N/A! :twisted:
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
PostPosted: Thu Feb 17, 2011 4:08 pm
Northstar runs the 4T80E. I highly doubt that controller would run either trans.
Interesting that you put "better" plug wires on it, considering that the Northstar has no wires, as it's a coil on plug design. What plugs did you use that are "better"?
PostPosted: Thu Feb 17, 2011 4:13 pm
Since I've been looking at magnums, one technique used with turbos before the code went public was a ninth injector.
PostPosted: Thu Feb 17, 2011 4:38 pm
1999 SE
I wouldn't rule out the controller. It may not be intended for it, but as with the general electronic and semi-electronic transmissions. It's Solenoid A on Solenoid B off, or any combination in between for the different gears. The thing that I'd be questioning is the PWM for the TCC(venturing a guess that GM stuck with PWM for TCC). That question would be best left to the people who made the controller.
Thanks for correcting me on which transmission the Northstar is coupled with. I wonder why they would put a 4T65 behind the LS4.... seems backward, but I'm not an engineer.
Last edited by mylittleblackbird on Thu Feb 17, 2011 4:43 pm, edited 2 times in total.
PostPosted: Thu Feb 17, 2011 4:50 pm
Not to completely hi-jack, but I think it's mostly because the 4T80E steals a lot of power, and they wanted to get as much to the ground as possible.
PostPosted: Fri Feb 18, 2011 1:14 am
Probably cost and packaging in the W body, the 4T80 isn't small, and they have different mounts. The LS4 has a smoother powerband, it gets into the torque a little easier than the supercharged cars the 4T65-HD was designed for.
There are no new unread posts for this topic. To supercharge, or not to supercharge?
Tazman3212
17
1261
Fri Dec 07, 2012 10:41 pm
Tazman3212 View the latest post
There are no new unread posts for this topic. 3.8 supercharge
bobapples55
Thu Sep 30, 2010 11:46 pm
This topic is locked, you cannot edit posts or make further replies. supercharge my 95 3800 or not?
dragonslit
Tue May 22, 2012 11:24 pm
J Wikoff View the latest post
There are no new unread posts for this topic. Supercharge my life!!!!!!
BOLTO57
Tue Mar 08, 2011 9:00 am
willwren View the latest post
There are no new unread posts for this topic. wanting to supercharge my 3800...
dragonslit
Thu May 24, 2012 10:23 pm
