It is currently Mon May 20, 2019 7:12 am
 Post subject: Dual Exhaust
PostPosted: Thu Nov 11, 2010 5:34 pm
OK I'm sure this had been asked before but since I didn't find it here goes again.
I'd like to put duals on my SE but not sure what kind and what fits best. :banghead:
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
 Post subject: Re: Dual Exhaust
PostPosted: Thu Nov 11, 2010 6:48 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
You could get a factory unit off an SSEi or SLE. Should fit perfect minus the fact that you dont have dual cutouts in your rear bumper cover.
PostPosted: Thu Nov 11, 2010 6:56 pm
Waste of cash IMO. No benefit.
PostPosted: Thu Nov 11, 2010 9:57 pm
Why does everyone get on about bumper cutouts? Plenty of cars don't run cutouts for tips, you just stick it out below the bumper? The SE bumper on 2000+ has a slight bend on each side that's right above where a tip would go anyways...
Besides, looks great to me :wink:
If you're going to do it and want some noise as well, new mufflers will help, but wont really add HP.
PostPosted: Thu Nov 11, 2010 10:05 pm
Your topic title conflicts with your post.
Dual exhaust is separate pipes all the way back for each side of the engine. Difficult and somewhat pointless on a FWD car.
Dual outlets will buy you nothing.
On the Bonnevilles of various generations that had dual outlets, the exhaust is 2.5" diameter all the way back to the muffler. From there, the earlier models (not sure about the 2k) drop down to dual 2.25's.
The surface area (opening of a 2.5" pipe is 4.9".
The dual 2.25's combined are 3.9 x 2 = worthless because you can't get something for nothing.
So are you interested in true dual exhaust, or just dual outlets?
If it's dual outlets, are you expecting a performance gain, or is this cosmetic?
PostPosted: Fri Nov 12, 2010 10:44 am
My mistake. I meant dual tips. But if there is no benefit to changing it except for a different sound then not worth the time or effort.
PostPosted: Fri Nov 12, 2010 2:24 pm
89 SkiDoo
I was getting at a fitment issue if he used a unit of an SSEi/SLE. Like where the tips sit they might just rub on the bumper cover without the actual cutouts. IDK. I was just throwing it out as a caution.
PostPosted: Fri Nov 12, 2010 3:45 pm
Because they will scrape on the ground if going up steep inclines.
Mine do sometimes even with the bumper cutouts.
Duals are purely cosmetic in his case. He'd be better off putting the money into new brake rotors. :wink:
PostPosted: Fri Nov 12, 2010 5:03 pm
I've had my mudflaps scrape, never my tailpipes.
PostPosted: Fri Nov 12, 2010 6:59 pm
Stock SE tips don't scrape, why would adding a second do that? The lower edge of the bumper is just higher up.
PostPosted: Fri Nov 12, 2010 8:28 pm
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
SE tail pipes don't scrape, but SLE & SSEI's do. & I belive they sit lower, so the SE bumper cover won't be an problem.
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
PostPosted: Sat Nov 13, 2010 2:07 pm
Year and Trim: 2001 Pontiac Bonneville SE
2005 Chevy Suburban Z71
I was thinking about doing the same thing but purely for cosmetic reasons.
There are no new unread posts for this topic. SE: Single exhaust to Dual exhaust conversion: How-to
Bugsi
Sat Dec 24, 2016 4:58 pm
mybonnelou View the latest post
There are no new unread posts for this topic. Dual Exhaust
OnlyAnSE
Sat Dec 17, 2011 10:13 am
willwren View the latest post
There are no new unread posts for this topic. True Dual Exhaust :)
voller1410
23
4648
Sat Dec 17, 2011 3:57 pm
voller1410 View the latest post
There are no new unread posts for this topic. dual exhaust and mufflers
psburtis
11
3827
Mon May 26, 2008 9:21 pm
Bugsi View the latest post
There are no new unread posts for this topic. Help with Dual alternator kit
CDouble
22
5555
Thu Jan 19, 2012 11:49 pm
