It is currently Mon Feb 18, 2019 8:52 pm
PostPosted: Mon Oct 25, 2010 1:11 pm
Year and Trim: 1997 SSE
I have just completed the engine swap, putting a 3800SC from what I believe is a 2000 Grand Prix GTP into my 97 Bonneville SSE which was normally aspirated. Pretty straight swap from the bolt up perspective. Swapping the flywheel was the only change I made to get it bolted up.
The engine is running and it seems close to right, but just not quite. Actually has stalled a couple of times today when stopped and idling after warm up. This is new behavior after driving about 700 miles on this engine.
1) The manual BBV I have left plugged into the solenoid because there is vacuum on the line coming from the manual diaphram. I've seen some posts saying to take that line off the solenoid. I don't have a wire on my harness for that solenoid so I plan to leave it unplugged. Should I be able leave the lines on and leave the solenoid unpowered?
2) After the car is warm at idle the "Check gauges" light (NOT Check Engine) comes on. I see no gauge indication of a problem. I suspect this is related to the alternator change. The alternator with the engine has 3 wires instead of the 2 my old alternator had. I only hooked up one of the signal wires and it seems to read right around 14V on the dash gauge, but does drop down to 13 at times. What should I check? Any suggestions on different wire up for this alternator?
3) Lastly and perhaps most important, I have read the ECM should be reflashed after this swap. Is this needed? What will it do for me? I think the engine is not as smooth at idle as the old one. Would this correct that issue?
PostPosted: Mon Oct 25, 2010 1:13 pm
What ECM are you using?
What are the CEL codes?
-Andrew-
PostPosted: Mon Oct 25, 2010 7:31 pm
This is my first trip down the 3800 swap lane so I don't know that I can answer your question with the detail that you require. I have kept the PCM that was in the 1997 normally aspirated car.
The CEL is off an there are currently no codes that I can find with a simple pocket scanner.
How can I get a more thorough answer for you?
PostPosted: Mon Oct 25, 2010 7:47 pm
You absolutely need to be running the supercharged PCM and wiring harness. I am stunned you have it running right now.
-Andrew-
PostPosted: Mon Oct 25, 2010 9:27 pm
Year and Trim: 2012 Eco
Seconded. Get the supercharged PCM in there ASAP. It has the right tables to run your engine.
PostPosted: Mon Oct 25, 2010 9:28 pm
Ungodly. Your MAF and fueling curves have to be WAY off. To the point of running dangerous piston-popping lean at anything above half throttle.
Get that setup right first. Don't drive the car.
There are no new unread posts for this topic. 3800 TO 3800 SUPERCHARGED
bonneowner
21
4737
Fri Aug 12, 2011 7:52 pm
bonneowner View the latest post
There are no new unread posts for this topic. Changing Spark Plugs & Wires - 3800 Series II Supercharged
Brae
12
7083
Sun Sep 15, 2013 9:55 pm
There are no new unread posts for this topic. GXP 3800 Swap
Freejack
Fri Sep 08, 2017 12:47 am
Freejack View the latest post
There are no new unread posts for this topic. Cadillac 3800 Swap?
94SilverSSEi
51
9556
Fri Jun 10, 2016 4:46 pm
Valuvan View the latest post
There are no new unread posts for this topic. 3800 to northstar swap on 95 se
soundman9826
Mon Feb 05, 2018 12:25 pm
