It is currently Fri Jul 19, 2019 11:15 am
 Post subject: 1999 Olds 88
PostPosted: Sun Jul 01, 2018 7:41 pm
Hi all, I have always found you guys to be able to help so here it goes. My dads 99 olds 88 is running terrible, it seems to run on all 6 cylinders if you ease the throttle but if you give it too much it clearly isn't running on all 6 cylinders. At a standstill it like surges back and forth then rpm increases and, sounds like when the engine is cold you have the noise from the egr valve even when its hot. Going down the road it would run fine then start running terrible all over again. I was hoping it was the maf sensor but, I unplugged that and made not difference like my wifes regal did. I looked at the ignition wires in the dark but did not see any arching. My dad did say he had problems with cylinder 6 blowing off the plug boot, not sure how that could happen. We did put the car in gear a while ago and under brake load it ran smooth that time which was strange, it is off and one (missing stumbling). It is showing check engine on the dash so I will runn to autozone to borrow their code ready, maybe that will show me something. Any help will be appreciated
 Post subject: Re: 1999 Olds 88
PostPosted: Sun Jul 01, 2018 9:24 pm
I won't even take a crack at it until I hear what codes it's throwing.
I would be curious to hear if it stalls or acts up when you pull the oil cap off while idling.
Is it consuming any fluids, and if so, what, and how much/how often?
PostPosted: Mon Jul 02, 2018 10:12 am
made no difference how the engine ran when taking the oil filler cap off.
3 codes showed up
#1- throttle position sensor
#2- MAf
# missfire
when my wife's regal had a bad maf, it would run with the sensor unplugged but, would shut off when plugged in while hot engine,
as far as losing liquids there is 2 choices, coolant and oil, not sure what your getting at with that. Coolant and oil are full and not needing to add any. The coil packs, wires and plugs are 9k old. Hate to go start buying parts off the cuff. I unplugged each ignition wire one at a time while running, some seemed to pop/snap while others didn't, although seems that the engine picked back up when connected some. I bought the bluetooth code reader from advanced auto believing it would read real time like the one at autozone said would do, it appears the this one does no more than the torque app for 5 dollars did, actually less
PostPosted: Mon Jul 02, 2018 11:41 am
What were the exact code numbers?
PostPosted: Mon Jul 02, 2018 2:51 pm
oh no, I cleared them and they are not setting again. It does not surge up and down anymore. Took it on a ride, to much stepping on the throttle and it's missing terribly, stepping down on the throttle more and its detonating/ popping back. Easing on the pedal it will run smoothly and accelerate slightly. Dad had a fuel filter so I changed that out, barely could blow through it but, did not solve the problem. Had the ignition module tested and it tested good. I will test the coils later tonight then, tomorrow I'm pulling the plugs and wires even though they are only 9K old
PostPosted: Mon Jul 02, 2018 4:58 pm
My thoughts are gravitating towards a possible exhaust restriction, typically a clogged/broken catalytic converter.
Easiest way to rule that out is to unbolt the down pipe from the rest of the system to see if it drives any differently.
PostPosted: Mon Jul 02, 2018 6:05 pm
fixed, I kept thinking it was ignition problems after all this so, I swapped our Regal coil packs over to dads, runs smooth as should. I just wonder why the tps seemed stop the engine surging. Told dad not to buy the cheapest ones again.
PostPosted: Tue Jul 03, 2018 9:59 am
Cheap sensors are always a bad choice, they get hot and stop working pretty quickly in my experience. Glad you got it sorted out!
"Penelope" - 2003 SLE - 190k Miles
"Sydney" - 2000 Honda S2000 - 63k miles
PostPosted: Tue Jul 03, 2018 12:03 pm
my experience has been to get the coil packs from the salvage yard, AC Delco, part 19352925. I got to www.gmpartsclub.com to get most of my part numbers. - BC
PostPosted: Sat Jul 07, 2018 8:02 am
1oldman wrote:
my experience has been to get the coil packs from the salvage yard, AC Delco, part 19352925. I got to http://www.gmpartsclub.com to get most of my part numbers. - BC
ended up buying Borg Warner coils from advanced auto, 35 each, could have got ac delco from rockauto for the same priced but, didn't have the time to wait for them.
PostPosted: Sat Jul 07, 2018 5:35 pm
$35 got me and ICM and 3 coil packs at the salvage yard, but that was a while back. - BC
There are no new unread posts for this topic. need help w/dads 94 Olds LS
Guest
Wed Oct 08, 2008 5:01 pm
Guest View the latest post
There are no new unread posts for this topic. 1986 Olds 88 won't start
bill buttermore
Thu Apr 22, 2010 10:46 pm
Archon View the latest post
There are no new unread posts for this topic. 98 or 99 Olds Intrigue W/Autobahn Package 3.8L
89OldsRocket
Fri Mar 28, 2014 6:34 pm
yourgrandma View the latest post
There are no new unread posts for this topic. Correct TPS sensor output for 90 Olds 88 w/3800
andx0r
Sun May 01, 2011 8:44 pm
There are no new unread posts for this topic. Enging Reving/Dash Flashing 96 Olds Regency
MooseGundr
Mon Jul 19, 2010 10:40 am
MooseGundr View the latest post
