It is currently Wed Feb 20, 2019 9:43 am
PostPosted: Wed Jul 22, 2015 3:58 pm
None of these ports work in my wife's 05 gp and I was wondering if it's as simple as a bad fuse. If so what would it be called on the diagram?
Dan
Scurro
PostPosted: Wed Jul 22, 2015 4:19 pm
Year and Trim: 2004 GTO
Sounds like a bad fuse, as my ports are powered all the time. Check fuse number 10 under the hood. It says auxiliary power, which is the closest I can find in the manual.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Wed Jul 22, 2015 4:24 pm
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Jul 22, 2015 5:53 pm
Awesome will check when she comes home
Dan
Scurro
PostPosted: Fri Jul 24, 2015 9:19 am
Year and Trim: 2001 SSEi
That fuse location is pretty cool. There are 3 slots for the fuse instead of 2. If you put the fuse in one way, it's powered all the time. If you use the other 2 slots, it's a key on curcuit. Pretty fancy I think! But, I'm pretty easily impressed I guess!
PostPosted: Fri Jul 24, 2015 11:46 pm
Got them working again. Not quite sure what you mean by 3 slots for it I only saw the one with only two holes.
Dan
Scurro
PostPosted: Sun Jul 26, 2015 2:19 pm
Sorry for the confusion. On my '01 SSEi, the space for the aux. power and the "cigar lighter" as the owner's manual calls it, is wider than the other fuse locations. Instead of having just a place for the two pins of the fuse, there are three pin locations. If you put the fuse in using the center and left pin location, it's a power on circuit, if you put the fuse in the center and right pin locations, it's a continuous power circuit which means you can continue charging your phone even when the car is turned off.
It may not be like this of your model.
Didn't mean to provide TMI.
PostPosted: Mon Jul 27, 2015 8:26 am
Year and Trim: 2004 GXP
My GXP is the same way. Nice feature.
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
PostPosted: Tue Jul 28, 2015 12:30 am
She has base model grand prix so nope. But thats good to know for my next car.
Dan
Scurro
