It is currently Fri Jul 19, 2019 11:10 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
PostPosted: Wed Mar 11, 2015 11:00 am
Year and Trim: 2004 GTO
Ok, as some of you know I am going to try the brembo upgrade on my GP with CTS-V brakes. I have some of the stuff together and I did a test fit just now. These won't clear the spokes on my wheels so I am going to need some spacers and longer studs. The studs shouldn't be an issue but I know that only certain spacers are safe to use, any recommendations?
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Wed Mar 11, 2015 11:02 am
I think what you want are the hub centric ones. Not sure entirely.
"Penelope" - 2003 SLE - 190k Miles
"Sydney" - 2000 Honda S2000 - 63k miles
PostPosted: Wed Mar 11, 2015 2:08 pm
If you're spacing your wheel out past where the hub isn't centering the wheel, you'll need hubcentric spacers.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Wed Mar 11, 2015 2:10 pm
Year and Trim: 2004 GXP
Or you could sell the wheels to me and buy CTS-V wheels instead... :beerchug:
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
PostPosted: Wed Mar 11, 2015 2:14 pm
CTS-V wheels would require a re-drill or adapters.
05 Suzuki DRZ400S
PostPosted: Wed Mar 11, 2015 3:01 pm
It was just a stab at trying to score the proper rims for my car...
PostPosted: Wed Mar 11, 2015 4:02 pm
I don't think they will need to come out that far. This is what it looked like while I was test fitting.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Mar 11, 2015 4:43 pm
You just have to figure out if the hub is still centering the wheel at that point.
Take the distance the hub sticks out past the rotor, subtract the depth of the chamfer in the hub hole of the wheel and subtract the distance of gap shown in that pic (as long as the caliper isn't touching). If you have a positive number, you're good to go.
05 Suzuki DRZ400S
PostPosted: Wed Mar 11, 2015 6:58 pm
I would also suggest leaving yourself enough room for new brake pads/rotors. It would be awkward putting new brakes on the upgrade, and finding you need more spacer.
PostPosted: Wed Mar 11, 2015 7:23 pm
The brembos use a fixed caliper. :wink:
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Mar 11, 2015 7:41 pm
Year and Trim: 2001 Bonneville SSEI 32,000 miles bone stock
Since I'm assuming you have been doing a bunch of research on this already, what all is involved in the swap other than the wheels not fitting? I think I'm going to be due for brakes soon and the car could use a little more stopping power. Is the bonnie the same as the GP brake wise? I'm not completely opposed to replacing wheels if necessary.
PostPosted: Wed Mar 11, 2015 7:51 pm
Randy (yourgrandma) has done them on his Bonneville so I know it's possible. You have to have 18's at the very least. And then it's calipers, pads, 2007 Mustang GT500 front rotors, zzp extended SS brake hoses, caliper bracket bolts and banjo bolts from an 00ish F body, and then these little sleeves that go around the bracket bolts as the new bolts are thinner (I don't know if that step is needed on the bonneville.)
I am following this write up.
http://www.grandprixforums.net/threads/ ... S-V-brakes
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Wed Mar 11, 2015 9:52 pm
If you're looking to keep your 17s, there's always F-body brake calipers or better yet C5 Z06 ones. Both will still fit under the 17 inch rim, and can be used with the stock rotor or the larger GXP rotors.
PostPosted: Tue Mar 17, 2015 9:01 pm
Well things aren't going so well, I did manage to figure out what size spacer I'll need, but in the process I snapped a stud. Also the caliper is slightly scraping the rotor, but I can fix that with washers. I want to have these done before the Michigan meet, but every time I attempt something I run into a snag so I have doubts.
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Tue Mar 17, 2015 10:50 pm
Just gotta keep at it, the meet is still a ways away.
PostPosted: Sat Mar 21, 2015 1:15 pm
Anybody know the hub bore size on GXP wheels?
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Sat Mar 21, 2015 2:07 pm
Year and Trim: 2003 SSEi.
LOTS of Mods
same as all of the GP and any other 5x115 GM car
PostPosted: Sat Mar 21, 2015 2:24 pm
So 70.1mm?
-Ryan
yourgrandma wrote:
Hi.
PostPosted: Sat Mar 21, 2015 2:43 pm
Year and Trim: 99 Regal GS
Should be 70.3 mm
1999 Buick Regal GS 3.4" pulley,SLP headers, fwi, pnp, gemini chain w/ other trans mods, 12" brakes, GR2's, STB's, 34mm front sway bar; The Summer DD
1982 Pontiac Grand Prix L36 and an hx35 turbo; It's pretty quick Mod list here
PostPosted: Sat Mar 21, 2015 2:50 pm
I just looked at a place that makes custom spacers for what I'd need for $60. But they want $25 for shipping so the search continues.
-Ryan
yourgrandma wrote:
Hi.
There are no new unread posts for this topic. does any body know what this noise is???
popcornplaya83
15
1621
Thu May 24, 2012 7:02 pm
There are no new unread posts for this topic. 04 Chevy brake light
samples08
Tue Aug 27, 2013 7:41 am
michtom View the latest post
There are no new unread posts for this topic. Stuck Brake Lines!
Tricked-T
Sat Jan 28, 2012 12:37 am
Tricked-T View the latest post
There are no new unread posts for this topic. 2000 Grand Prix Parking Brake
94SSEgold
Fri Jun 12, 2009 8:24 pm
94SSEgold View the latest post
