It is currently Sun Feb 17, 2019 10:43 am
PostPosted: Tue Jul 29, 2014 8:34 am
Year and Trim: 1998 SSEi
Black
I bought the stage II Alternator Voltage Booster from ZZP but didn't realize this doesn't fit my bonneville. So it's new and unused. Sells for $26 on thier website for the stage II. Make me an offer! I believe its only for Grand Prixs
http://shop.zzperformance.com/store/p/235-Alternator-Voltage-Booster.aspx
1998 Black SSEi, All original with no mods (214k miles) Daily driver {purchased in 2003 with 39k miles}
2010 Black Camaro SS, muffler delete, CAI, Diablo tune, carbon fiber hood (60k miles) Weekend driver {purchased new 2009}
2014 Metallic Green Explorer, no mods, (45k miles), vacation/road trip driver {purchased new 2013}
PostPosted: Tue Jul 29, 2014 8:52 am
It will work on 2000+ Bonnevilles. I have one installed.
PostPosted: Tue Jul 29, 2014 9:23 am
Black
I figured it would fit mine because on their webiste it said doesn't fit 96/97 Bonnevilles so I assumed it would fit my 1998. :sad:
PostPosted: Tue Jul 29, 2014 11:50 am
x2
PostPosted: Sat Aug 23, 2014 3:02 pm
Black
Sold this a few weeks ago on craigslist.
PostPosted: Sun Aug 24, 2014 4:21 am
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
Seems like snake oil to me.
If the original alternator is working properly and the electrical connections are in good shape then the electrical system will be running to its design parameters.
Increasing the voltage risks blowing fuses or burning bulbs out early.
Has anyone done a before and after voltage measurement?.
Roger.
PostPosted: Sun Aug 24, 2014 11:16 am
I have. It raises it by .5-.7 volts according to my Aeroforce. My heated seats were warmer, along with my rear defrost working quicker. Windows were a tad faster as well. Nothing extremely noticeable though. I wouldn't buy one new.
PostPosted: Tue Aug 26, 2014 12:15 pm
Year and Trim: 2003 SSEi.
LOTS of Mods
I also have the Voltage Booster on my car, I dunno if it helps but does raise the voltage
PostPosted: Tue Aug 26, 2014 5:03 pm
I installed a voltage booster for the fuel pump.....essentially a direct power supply.....more voltage, more flow, more power.
PostPosted: Wed Aug 27, 2014 3:40 am
1989 Buick Le Sabre
Really?.
The engine only requires enough fuel to give an ideal air/fuel ratio, I doubt a standard fuel pump in proper working order couldn't keep up.
Roger.
PostPosted: Wed Aug 27, 2014 10:22 am
Roger,
It depends on what mods you have done to the engine. In my case, I need the extra volt bump in pressure/flow.
I agree that with a stock engine, the stock fuel injection system running at 12 volts is just fine.
When your DIC reads 14 volts, there is only around 12 volts going to the fuel pump. The gauge of wiring the factory uses is smaller than ideal.
