It is currently Thu Jul 18, 2019 3:13 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Aug 27, 2013 12:19 am
Friend of mine has a 98 Intrique that I helped him buy. The car has 200k on it, but has a new engine with 60k installed. Also a new radiator was installed before he bought the car. He has owned it for a few months, and never really overheated until it got really warm out. It will get as hot as 250° before he has to shut it down and let it cool. I haven't diagnosed it in person yet, but this is what I know.
New radiator
New thermostat (180°)
New water pump
New intake gaskets
New UIM
Fans are working properly
No oil in coolant
No coolant in oil
No white smoke
Coolant is boiling, but not over, no steam
No air in system, has been burped properly
You can feel the coolant running through the hoses when you squeeze them
My dad suggested checking to make sure the condensor is getting proper flow and isn't blocked with dirt, bugs or bent fins. I'm gonna check that out when I see the car on Thursday. Any other suggestions, even far-fetched are appreciated. We are all really stumped on this one.
-Andrew-
PostPosted: Tue Aug 27, 2013 12:22 am
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
This may be a stupid question. But has the coolant been tested to see if the coolant/water ratio is correct?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Tue Aug 27, 2013 12:27 am
Definately something else to check, thanks.
-Andrew-
PostPosted: Tue Aug 27, 2013 3:41 am
Check or replace the radiator cap. Also verify the pump is working. I remember in the past there was a case or two where the impeller of the pump broke.
PostPosted: Tue Aug 27, 2013 8:29 am
Year and Trim: 2003 SSEi.
LOTS of Mods
agreed with the cap. I think the Intrigue uses a Pressured system, that is different than the Bonneville.
Also, are you sure that the temp gauge is correct?? Its a long shot but something to think about
PostPosted: Tue Aug 27, 2013 9:22 pm
Year and Trim: 2009 G8 GXP
Maybe something in the system is clogged. Like to a point that is has flow, but really restricted flow. Do you happen to know if anyone dumped stop leak in the radiator?
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
PostPosted: Tue Aug 27, 2013 10:02 pm
Coolant has been tested, exactly 50/50.
New radiator cap.
Condensor has been cleaned out, lots of junk in it.
However, still overheating. Like Terry was saying, it has to be plugged somewhere. When he comes on Thursday I'll do an extensive examination.
-Andrew-
PostPosted: Tue Aug 27, 2013 10:23 pm
Is it possible or worth taking the engine apart to see how the coolant ports/channels look? If they are as gunked up as mine were, I could see why it would overheat.
2005 Grand Prix
PostPosted: Tue Aug 27, 2013 11:15 pm
I know that it is unusual, but check compression, or do a cylinder leak down test to check the condition of the head gaskets. The bubbling could be exhaust gas getting into the coolant.
PostPosted: Wed Aug 28, 2013 5:07 pm
I would wonder if something in the block is clogged up, I remember somebody on here finding bits of an old water pump impeller in their coolant channels.
Current fleet:
PostPosted: Thu Aug 29, 2013 11:51 pm
Had a look at it tonight.
Tested that the coolant temp sensor is working correct, yes it is.
Flushed out the block and radiator, both are flowing just fine.
Water pump is working.
Did a compression test: 135-150 across the board.
Only thing we can come up with now is that the radiator is not working correctly. Not getting proper airflow? Wrong size core? The bumper cover doesn't really allow much airflow as it is. I think I might take the cover off and see if it cools better. I gave him one of my cars and I'm holding onto it until I can get it figured out. Any more ideas are welcome.
-Andrew-
PostPosted: Fri Aug 30, 2013 9:44 am
I am curious. Does it heat up worse when driving? If you let it idle when it starts getting hot, does it cool back down with the fans, or does it keep escalating? How does the A/C work?
PostPosted: Fri Aug 30, 2013 11:22 am
AC works fine.
It gets hot whether is idling or driving at full speed. The fans do nothing.
-Andrew-
PostPosted: Fri Aug 30, 2013 11:29 am
Does the temp go down after turning heat on high when driving it? I battled a similar situation with a 1990 Pontiac Sunbird and led to head gasket failure 40k later. Are head gaskets good?
I'm sure you have bled system and relieved any air pockets?
Eric
A few mods..
PostPosted: Fri Aug 30, 2013 11:33 am
Why was all of the recent work done? Was it to try and fix this problem?
And did the issue suddenly appear, or it got worse and worse as it got warmer?
PostPosted: Fri Aug 30, 2013 11:36 am
And you did clean out between the condenser and radiator correct? Or at least look in there?
PostPosted: Fri Aug 30, 2013 11:46 am
Fans don't work, or they don't sufficiently cool it off?
PostPosted: Fri Aug 30, 2013 12:26 pm
I'm assuming that they just don't sufficiently cool it.
I never noticed before that these cars don't seem to have a grille.
"Penelope" - 2003 SLE - 190k Miles
"Sydney" - 2000 Honda S2000 - 63k miles
PostPosted: Fri Aug 30, 2013 3:33 pm
He said it does it when driving full speed, so I think he meant fans do not bring the temp down.
yourgrandma wrote:
High
PostPosted: Fri Aug 30, 2013 3:58 pm
Year and Trim: '02 SSEi
Make sure the shroud for Tue radiator is intact. There's a duct that guides the air up from under the car. Without that it won't get any air at all.
There are no new unread posts for this topic. 97 grand prix troubles and iam stumped
razmatazz
Tue Mar 20, 2012 12:18 am
razmatazz View the latest post
There are no new unread posts for this topic. 1998 gtp
Adam Marcum
Wed Mar 17, 2010 6:33 pm
There are no new unread posts for this topic. Need electrical help - 1998 Regal LS
Hotwheels
Sat Jan 11, 2014 11:29 pm
Hotwheels View the latest post
There are no new unread posts for this topic. 1998 grand prix
swiles
Mon Dec 21, 2009 11:48 pm
swiles View the latest post
There are no new unread posts for this topic. 1998 GP GTP Issues and Suggestions...
yonkerse
Mon Oct 03, 2011 9:53 pm
