It is currently Thu Jul 17, 2025 12:28 pm
PostPosted: Sat Jun 12, 2010 4:54 pm
Year and Trim: 1995 SSE, 2001 Buick Park Avenue
OK, I admit I'm not all that observant about cars, so my failure to notice this at first may seem stupid.
My wife's 2001 Park Avenue with split Driver/passenger ECC started failing intermittently to turn on the blower recently. And now it's more off than on, so the AC isn't working.
On both my '94 Sedan DeVille and my '95 SSE this was the blower control module, and it's under the hood down behind the MaxiPanel on the firewall.
I thought I'd have an easy time on the Park Avenue, expecting it to be in the same place. But it's clearly *NOT* the same.
First, on this model am I correct that it's probably the blower control module?
And second, looking under that dash it seems like there's a whole lot to pull out to get to the HVAC. What am I missing here? Is there some panel under the hood that I failed to see, and this is really similar to the mid '90s vehicles? Or do I have to tear out all that stuff under the dash to get to it?
Thanks,
Michael
PostPosted: Sun Jun 13, 2010 10:21 pm
If the system is similar to the Bonnevilles, and it appears that it is, the blower motor itself is the more likely cause. Both the blower motor and the blower motor control module is behind the right side of the dash. If you pull off the lower panel, and look up, you should be able to see it. When it won't start, try tapping on the motor and see if it starts up.
PostPosted: Sun Jun 20, 2010 8:32 am
OK, this got me in the ball park, and you are right. The module is fine. The real problem wasn't the motor proper, but rather the cheesy electrical connector on the motor.
I'll post some pics of how I fixed it as soon as I can get to it. Hopefully I can help save someone $500. My total costs for the repair was time and some complaints from my wife about the heat.
Michael
PostPosted: Sat Jul 17, 2010 1:46 pm
Year and Trim: 2006 Buick Lacrosse CXS
On my dads 01 Park Ave the connector melted inside and we replaced it.
There are no new unread posts for this topic. 2001 Park Avenue Security light
michaelbsc
18
10828
Tue Jan 05, 2010 9:10 pm
1fatcat View the latest post
There are no new unread posts for this topic. Door Hinge Adjustement - 2001 Park Avenue
97seagain
Fri Jul 17, 2009 11:52 am
Archon View the latest post
There are no new unread posts for this topic. Need Help with 2000 Park Avenue
Ponch 04
Sun Jul 04, 2010 5:09 pm
Ponch 04 View the latest post
There are no new unread posts for this topic. Will a 96 park avenue subframe go into a 99 regal?
94SilverSSEi
Thu May 27, 2010 6:36 pm
sandrock View the latest post
There are no new unread posts for this topic. 1996 Buick Park Avenue HELP-Engine
00ssei
Wed Oct 08, 2008 2:01 pm
bill buttermore View the latest post
