It is currently Thu Jul 18, 2019 3:26 pm
 Post subject: 1998 gtp
PostPosted: Fri Mar 05, 2010 9:46 pm
Year and Trim: 1999 regal gs
i just got a 1998 gtp with 166,000 miles. i think the supercharger is making a noise how do i replace the coupler ..it is a rattling sound but not all the time just at idle.
1999 regal gs
 Post subject: Re: 1998 gtp
PostPosted: Fri Mar 05, 2010 10:28 pm
This will get you started.
viewtopic.php?f=56&t=3208
PostPosted: Fri Mar 05, 2010 10:49 pm
thank you ..
1999 regal gs
PostPosted: Wed Mar 10, 2010 7:11 pm
Make sure it is not the harmonic balancer.
PostPosted: Wed Mar 17, 2010 5:58 pm
Ok it was the coupler. now on to other stuff?what size is the exhaust were it goes into the cat..i have found a d/p with cat it goes from 3"tell it gets to the cat then it is 2.25for the high flow cat then back to 3" with the u bend delete.. will it work for my car? or should i find a full 3" set up?and do stock muffler flow good? i don't wont a loud car... i wont to drop to a 3.6 or 3.5 pulley can i with the d/p ..fwi..and colder plugs and a 180 t-stat..and do i have to have the pcm tuned ..right now i have no KR..
1999 regal gs
PostPosted: Wed Mar 17, 2010 6:33 pm
Get a full 3" DP/cat. Your exhaust is only as good as its weakest link, currently that's the U-Bend, and with that setup it would be the cat. If you kept a stock muffler, your exhaust would still be quiet, with just a little more roar at WOT and at cold idle.
There are no new unread posts for this topic. Need electrical help - 1998 Regal LS
Hotwheels
Sat Jan 11, 2014 11:29 pm
Hotwheels View the latest post
There are no new unread posts for this topic. 1998 GP GTP Issues and Suggestions...
yonkerse
Mon Oct 03, 2011 9:53 pm
There are no new unread posts for this topic. 1998 grand prix
swiles
Mon Dec 21, 2009 11:48 pm
swiles View the latest post
There are no new unread posts for this topic. 1998 GTP Misfiring problem, and need some troubleshooting
2000GreySSEi
Mon Nov 07, 2011 7:19 pm
There are no new unread posts for this topic. 1998 Regal 3.8 P0401 & P0171
Hotwheels
Fri Feb 14, 2014 1:03 am
