It is currently Sat Jun 22, 2024 10:46 pm
PostPosted: Thu Jul 16, 2009 11:58 pm
2004 Camry
1969 Chevelle
I'm not sure if the hinges are the same as the Bonne's, but my drivers door sags a bit, and it doesn't seem like the hinges have play. I replaced the door check strap since it was noisy, but it didn't help.
So my question is... I assume the hinges can be adjusted, I just don't see any "slots" where I can loosen the bolts and move the door around. Is it done on the body end of the hinge, or the door end?
Thanks!
PostPosted: Fri Jul 17, 2009 11:52 am
This is what I have for instructions.
Position the door fore or aft at the body hinge pillar attachment. Perform the following steps as needed:
Loosen the fasteners.
Reposition the door.
Tighten the fasteners.
Tighten the fasteners to 34 N·m (25 lb ft).
Adjust the lock striker.
If more adjustment is needed, remove the door.
Remove the hinges from the pillar and the door.
Ream the stud holes in the pillar side of the hinges in order to allow for more adjustment.
Reinstall the hinges to the pillar and the door. Leave the nuts on the pillar side of the hinge loose.
Align the door as needed.
There are no new unread posts for this topic. 2001 Park Avenue Security light
michaelbsc
18
9941
Tue Jan 05, 2010 9:10 pm
1fatcat View the latest post
There are no new unread posts for this topic. Where is the blower control module on 2001 Park Avenue?
michaelbsc
Sat Jul 17, 2010 1:46 pm
white06lacrossecxs View the latest post
There are no new unread posts for this topic. Need Help with 2000 Park Avenue
Ponch 04
Sun Jul 04, 2010 5:09 pm
Ponch 04 View the latest post
There are no new unread posts for this topic. Will a 96 park avenue subframe go into a 99 regal?
94SilverSSEi
Thu May 27, 2010 6:36 pm
sandrock View the latest post
There are no new unread posts for this topic. Buick Park Avenue 91 sunroof leakage
widowmaker
Wed Mar 24, 2010 3:16 pm
widowmaker View the latest post
