It is currently Sat May 25, 2019 4:57 am
PostPosted: Sun Oct 03, 2010 5:34 am
Year and Trim: 1997 Chevy Camaro Z28 6MT
2013 BMW 135i DCT
60'.....2.026
1/8.....8.597
mph....84.19
1/4.....13.263
mph.....105.99
...on street tires, with drag radials or slicks this would be a 12 second car.
:bow: Your move Paul......rematch with the trans am?
1997 Camaro Z28: LT1 with a proper 6-speed gearbox, Centerforce clutch, Bilstein struts, Ground Control adjustable springs, LCAs, PHR, SFCs, EBC Yellow brake pads, K&N intake, Comp Cams 502 (duration 218/224 @.050, lift .495/.503), LS6 valve springs, Pacesetter long tube headers, 3 inch Magnaflow exhaust, custom PCM tune by Wong's Performance Engineering in Vancouver, WA.
2013 BMW 135i: 3.0 liter turbo I6, 7 speed Dual Clutch Transmission, M-Sport package, bone stock.
Sold, but missed: 1996 Bonneville SSEi, 3.4 pulley, Intense intake, Zilla Motorsports ported LIM.
PostPosted: Sun Oct 03, 2010 7:38 am
Nice job! I would have gone, but had other things going on. Do you have any plans to put slicks on it?
PostPosted: Sun Oct 03, 2010 12:23 pm
Congrats Man!!! :beerchug:
PostPosted: Mon Oct 04, 2010 3:07 pm
2013 BMW 135i DCT
Thanks! I'm not gonna spend the money to run slicks, I know it'll be a 12.9-12.8 or so pass. Plus I'll start putting more strain on the stock 7.5 inch diff, which I don't want to risk grenading just to run a few tenths quicker. I'm calling this "enough" before it gets really expensive. The camaro is a reliable easy driver/weekend racer; if I keep going I'll end up spending more time and money fixing it than driving it.
PostPosted: Mon Oct 04, 2010 3:39 pm
Good run and wise decision. Good to see that you can keep up to a 5.0 Stang now. :P
If I attend WCBF for another rematch it'll likely be with the SSEi.
So ya, I'll run against you again and it'll be a much more even match regardless of which car I finally decide to bring. :twisted:
......it's a Formula Firebird, not a TransAm. [-X
There are no new unread posts for this topic. I hit a dog tonight.
GoldenBullet
21
2118
Wed Jan 14, 2009 11:37 am
This topic is locked, you cannot edit posts or make further replies. got a warning tonight from the law for....
Sat Nov 22, 2008 12:47 pm
There are no new unread posts for this topic. Hit the strip tonight...
superchargedSSEi
Fri Nov 07, 2008 10:36 am
There are no new unread posts for this topic. Hitting the track tonight
FunkRider
25
1658
Fri Oct 22, 2010 2:04 pm
There are no new unread posts for this topic. well the gtp got hit bye a drunk driver tonight
Adam Marcum
18
1495
Thu Apr 29, 2010 12:33 am
