It is currently Thu Jan 17, 2019 5:51 am
Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Oct 28, 2010 8:21 pm
Year and Trim: sold
2000Silverbullet wrote:
Wheelie bars Jarod.......just like Scott did! :wink:
....and hardened trani internals. :P
Internals where hardened until they exploded, LOL. I started to actually hook them up with 1.77s and then the tranny went poop before I could nail that 11. I still think its there.
2000 SLE
PostPosted: Thu Dec 30, 2010 8:48 pm
Year and Trim: 2003 SSEi
Ahmet Cunmulaj
2003 SSEi
stock heads
S1X cam
home ported stock Gen 3
other mods:
ZZP S3 IC
65# Siemens
3.0"(10psi)
E85
odds and ends:
stock all season tires @ 28psi
full weight(just over 4000lbs)
STOCK TRANS
STOCK TB + MAF
base tune by me(no wideband for the E85 yet, soon to come)
From left to right:
60': .........2.0508........................ 2.1548................................ 2.2987
1/8mile: ...8.5196@85.37............ 8.5522@85.16....................... 8.84@85.16
1/4mile: ...13.0578@108.17........ 13.0978@110.35..................... 13.3671@112.36
on my best ET and 60' i had a spike of 3.6* of KR that fadded away for some reason. other runs KR free.
03'SSEi(DD since 07')- S1X, S3 IC, SLP headers, JMB FWI, PRJ rails, 65#'s, 2.9", 19* timing, HP Tuned... 310.3whp/411.6wtq(dynojet/pump gas)... after dyno: E85, 72mm TB, and tuning 2.8"@ 22*... 12.8@111mph(full weight, all season street tires, no track prep)
PostPosted: Thu Dec 30, 2010 8:57 pm
heyy, thats #6 in E.T. and #3 spot in MPH trap... i took it easy on her this year. wideband and Tune are ASAP. then Trans and slicks by summer.
PostPosted: Thu Dec 30, 2010 9:20 pm
Not bad. Should be 12.5 second car with better 60 foot times after you get some slicks. =D>
PostPosted: Sun Nov 04, 2012 9:27 pm
1999 GTP
2001 Aztek GT
Tom Glover (TommyGloves)
2003 SSEi
Heads: Triple Edge Perf. L32 P&P
Cam: Intense S1x
Power Adder: GenV
60' Time: 1.865
1/8 mile time and mph: 7.935@ 90.35
1/4 mile time and mph: 12.334 @ 111.39
My Triple Edge Performance transmission is still holding up like a champ.
Tommy
03 Pontiac Bonneville SSEi - Daily Driver
| 06/10: 12.570@108.82 (1.831 60') | Best 60':1.824 | Best 1/4 MPH: 110.36 |
99 Pontiac Grand Prix GTP
Currently being tuned
PostPosted: Mon Nov 05, 2012 1:14 am
Very nice!!!
PostPosted: Mon Nov 05, 2012 4:24 am
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
A testament for TEP trans' for all the new guys that are having trans troubles and thinking about rebuilds!
PostPosted: Sun Nov 18, 2012 4:08 pm
New PB a month or so ago at Pittsburg raceway.
12.96@111.9 and then a 12.83@110.9 with my best 60' of a 2.09...
Same circumstances as my last post. Stock heads/gen3. Full weight, full tire pressure all season tires. No prep at all. But I did have the 2.8" on at 22* of timing.
The slip pic is on Dragtimes.com if u don't believe me. Lol
PostPosted: Sun Nov 18, 2012 6:50 pm
Year and Trim: '02 SSEi
Ruh roh . Some pretty quick times. Might have to try my hand at the straight line stuff for some grins.
PostPosted: Mon Nov 19, 2012 7:01 pm
89 SkiDoo
You should link the pic of the slip or post the pic here.
PostPosted: Thu Jan 03, 2013 5:46 pm
heres the link to dragtimes...
http://www.dragtimes.com/Pontiac-Bonnev ... 24808.html
heres the slip...
http://www.dragtimes.com/2003-Pontiac-B ... 24808.html
PostPosted: Thu Jan 03, 2013 6:18 pm
1999 GTP
2001 Aztek GT
slickbonny wrote:
:beerchug: Get some QTPs or DRs at least. ;)
Tommy
PostPosted: Fri Jan 04, 2013 1:42 am
89 SkiDoo
slickbonny wrote:
E85, gotcha.
PostPosted: Sat Jan 05, 2013 9:07 pm
slickbonny wrote:
no signs of tranny slippage?
PostPosted: Fri Apr 19, 2013 3:08 pm
Year and Trim: 00 Bonneville SSEi
Updated. Congratulations on the new times and good luck to those going out this year :)
Stay safe...
Mod List
PostPosted: Mon Jul 08, 2013 7:07 pm
Year and Trim: 2004 GTO
Best run I had yesterday. I was car #611 on the left.
20 psi in the front tires ,sub in the trunk and just over 3/4 tank.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Wed Sep 04, 2013 9:44 pm
Year and Trim: 2003 SSEi.
LOTS of Mods
new one for for me....looks like #5 for me
Pat Strittmatter (2003 SSEi)
2003 SSEi
Heads: Stock
Cam: Stock (1.9 Rockers)
Power Adder: GenV
60' Time: 1.8521
1/8 mile time and mph: 8.0907 @ 86.52
1/4 mile time and mph: 12.6622 @107.35
PostPosted: Sun Aug 31, 2014 4:55 pm
1993 Bonneville SSE
William Booze
2001 SSEi
Heads: Stock
Cam: Stock
Power Adder: Gen V M90
60': 2.08
1/8: 8.91 @ 78.81mph
1/4: 13.85 @ 102.13mph
'93 SSE "Guinevere" Mods: Intense FWI | 180º T-Stat | Flowmaster 80 | Magnaflow Cat | Projector Fogs | Clear Corners | ES Poly End Links
Achievements: Guinevere - 264k mi | 16.27 @ 84.10mph | March '11 COTM :: Chloe - 223k mi | 13.85 @ 102mph | January '09 COTM
PostPosted: Tue May 24, 2016 2:37 pm
Updated. Sorry for the delay ;)
Whoops, forgot Pat. I'll fix that shortly.
Mod List
PostPosted: Tue May 24, 2016 2:45 pm
Done, no more 14's in the top 25
Mod List
There are no new unread posts for this topic. 1/4 Mile times....
01bonneSC
Tue Jun 03, 2008 6:19 pm
SuperSLE View the latest post
There are no new unread posts for this topic. aeroforce 1/4 mile times oldsmobile lss
oldslss
Wed Apr 03, 2013 1:04 pm
There are no new unread posts for this topic. Woodburn Drags Official Times for spoiledred94
spoiledred94
43
3707
Tue Sep 16, 2008 7:13 pm
clm2112 View the latest post
There are no new unread posts for this topic. Official Michigan Meet(II) Time slip Thread.
Peterg22000
21
3325
Sun Oct 24, 2010 10:26 pm
repinS View the latest post
There are no new unread posts for this topic. Took the '03 to the track EDIT timeslip posted!!! (14.42!!)
crash93ssei
16
1711
Wed Oct 21, 2009 2:40 am
