It is currently Sat Feb 16, 2019 3:06 pm
Post new topic Reply to topic  [ 181 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
PostPosted: Mon Jun 08, 2015 6:37 pm
Year and Trim: 2004 GXP
Zipties count as secured, as long as the battery can't fall out. Otherwise I do have extra battery tie downs.
When I raced the LeSabre, I didn't have a battery tie down - I was allowed to race because the hinge for the hood and the A/C lines held the battery from moving when the hood was closed.
BBamm - that's horrible. But I know how you can take your mind off it, come to the meet anyway!!! A weekend relaxing with friends isn't just about your car. But in all seriousness, sometimes it's good to take your mind off the worry and blow some savings for a car meet; the biggest expenses are usually food and gas.
I hope everything gets sorted out for you in a timely manner though - there is always Woodward or next year!!
Wish I could... it's our anniversary on Monday anyway so I was pushing it by going and now with the problems... I just can't swing it. By the way, the seller sent a response to paypal saying they have receipts!! Paypal told me that's just a stall tactic and once they prove otherwise, they'll continue the investigation! Still at least a week out on getting my money it sounds like though...
:banghead:
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
PostPosted: Mon Jun 08, 2015 7:05 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Wes wrote:
I picked up a few loaf pans that are 9" x 5" x 3" to try a different technique instead of making a sprue tree. This will have better venting, and should reduce our chances of having gas pockets. If I drilled the corners to accommodate wire handles, would you feel safe using a hook to set these molds into the aluminum vacuum chamber to reduces bubbles further? The vac chamber is basically just aluminum tubing. It has about 12" ID, with a 30" or so depth. We would probably want to set a few bricks in the bottom.
Shouldn't be an issue, how does the vac chamber work, you put the molds in after the pour?
The melt furnace fired right up, this is at the lowest pressure the regulator will go:
So far I'm setting everything up to be a 2-man operation. Two people will have to pull the lid off, then do the pour, replace the crucible and lid. Sounds like we may need a third person to transfer the mold to the vac chamber while the first two reset. At the end, we will have to pour out whatever is left, so I'll see what I can do to make an ingot mold.
Runs:
Doesn't run:
PostPosted: Mon Jun 08, 2015 7:19 pm
Year and Trim: 1988 LE
Id have no problem helping with the furnace if need be.
-Austin-
yourgrandma wrote:
And thats how I got my mom pregnant.
PostPosted: Mon Jun 08, 2015 7:37 pm
That would be sooo awesome to be a part of, I'd help if I could make it.
I'm sure you guys will have a great time!
PostPosted: Mon Jun 08, 2015 8:23 pm
If we had a vac chamber that could withstand the heat of molten brass, we would set the mold in the chamber, then pour, and immediately vac. Since the chamber is aluminum, I was thinking we would pour until we see metal come out of the riser(s), then immediately take the mold to the chamber for probably 15-20 mins at full vac. Not sure how much the vac will help, but I don't think it would hurt in any way.
The burner offset looks good, but I think we will heat the metal up faster, and use less fuel if we make a cylinder type shape with the bricks to help the flame wrap around the crucible. This will also help prevent having a hot spot. Do you have enough bricks to do something like that? If not, bringing in the walls closer to reduce the brick to crucible gap would be better.
Anyone know if flux will be necessary for such a small cast? Or is that more for when the metal is kept molten for long periods of time?
yourgrandma wrote:
High
PostPosted: Mon Jun 08, 2015 9:13 pm
'05 STS-4
'97 LeSabre
From what I've researched, we would need a flux of crushed charcoal (I have) for copper/brass, then a skimmer has to be held in place while pouring to keep the flux out of the pour. But aluminum only needs to be skimmed before pouring.
I have enough bricks to make it octagon-ish in shape by adding them in the corners of what I've already build, they just weren't in there for the first fire. I also need to figure out a lid that has a 5" or so hole in the middle, that plus the entry angle should create a nice vortex around the crucible and allow us to easily monitor the melt. Incidentally, that's similar to how you create a whirlpool in water: Bottom center drain, top tangential feed.
I got the tongs 90% done, ran out of wire in the welder, one weld short of a finished product..
Do you have access to any ceramics cones? If not I'll have to rig the kiln overheat safety. As long as we can monitor the temp on a regular basis we can control that manually.
Runs:
Doesn't run:
PostPosted: Mon Jun 08, 2015 9:58 pm
Cones? You mean the ones to monitor temp? I am unfamiliar with how those work as a hi temp safety. In my head I thought we would just tie the heater element leads to a 40A relay that is controlled by PID. Maybe I am not on the same page though.
I have a few J type t/c for the PID I am bringing. It is rated to 770C. Our peak will be 730C for the burnout cycle.
yourgrandma wrote:
High
PostPosted: Mon Jun 08, 2015 10:23 pm
'05 STS-4
'97 LeSabre
Yeah, cones.
https://www.bigceramicstore.com/info/ce ... chart.html
The kiln has a 50A 208V plug, there are 5x's 10A heating elements in it. If the PID can plug into a 50A 208v single phase receptacle and has a 50A outlet for the kiln, we're all set. If not I can figure it out as long as there is a schematic that comes with it, but if that's the case then it might take a few hours on Thursday to get it set up.
Runs:
Doesn't run:
PostPosted: Mon Jun 08, 2015 10:39 pm
I will bring a couple relays then. The PID will take single phase 120-240V, and same for the relays, but no outlet. I have an empty panel to mount them in where we can safely make our splices instead of having open wires though, and that can have what ever plug we need added to it. Can you snap a pic of the outlet that you have in the pole barn? I may have a plug here already if the one on the kiln doesn't match. Not too worried about having a schematic, should be pretty easy to wire up.
yourgrandma wrote:
High
PostPosted: Tue Jun 09, 2015 1:42 pm
Is there any real interest in going to check out the detail shop and doing a little tour, maybe checking out some tools and products? Looks like the schedule is filling up so I need to know.
PostPosted: Tue Jun 09, 2015 1:45 pm
Year and Trim: 2003 SSEi
I like the idea but schedule is pretty full. I think we should do it as a back up plan if the track gets rained out Friday maybe? Just my 2 cents.
-Nick
PostPosted: Tue Jun 09, 2015 2:24 pm
'05 STS-4
'97 LeSabre
I would agree that we need a backup plan if we get rained out on Friday.
Runs:
Doesn't run:
PostPosted: Tue Jun 09, 2015 2:41 pm
Forecast is calling for rain all weekend :sad:
yourgrandma wrote:
High
PostPosted: Thu Jun 11, 2015 12:16 pm
Heading out shortly. Hope I didn't forget anything!
yourgrandma wrote:
High
PostPosted: Thu Jun 11, 2015 12:38 pm
On the way now we will be there at about 10 PM. Did you ever post your exact address Matt?
-Austin-
PostPosted: Thu Jun 11, 2015 1:11 pm
The address is posted in the Facebook group for the meet, otherwise PM him for it.
Looks like rain, I don't care, I'll have the tent set up and ready to rock!
PostPosted: Thu Jun 11, 2015 2:48 pm
Year and Trim: 2011 Kia Optima SX
2014 GMC Sierra
When is the coin minting happening? I got 2 pieces of copper to use for them. One is a fairly large block, apx 3" x 5" x 6". Do you have something to cut it down with or should I have it cut in advance?
Marc
Not enough mods for me yet
Too many mods for my wife already
PostPosted: Thu Jun 11, 2015 3:12 pm
Year and Trim: 2004 GTO
We are doing the coins Sunday, and yes Matt has something to cut the copper with.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Thu Jun 11, 2015 3:44 pm
2014 GMC Sierra
Ok, I'm still debating if I'm coming Saturday or Sunday. If I'm coming Sunday I'll be there early.
Marc
PostPosted: Tue Jun 16, 2015 6:29 pm
'05 STS-4
'97 LeSabre
I have a list of things left behind, a towel, a chair, a chair, an umbrella, tent bag, hot dog stakes. PM me to claim them (so far figured out a few items).
Meet pictures:
on-the-road-and-at-the-track/topic46386.html
Runs:
Doesn't run:
There are no new unread posts for this topic. Michigan Summer meet 2016
MattStrike
77
9405
Mon Jun 20, 2016 7:28 pm
Vegafan View the latest post
There are no new unread posts for this topic. Michigan Mega Meet '11 June 23rd -27th update 5-10
[ Go to pageGo to page: 1 ... 7, 8, 9 ]
crash93ssei
165
14745
Wed Jul 06, 2011 1:01 am
wake View the latest post
There are no new unread posts for this topic. Michigan area meet, July 11th - 18th UPDATE 7-5 first post
[ Go to pageGo to page: 1 ... 10, 11, 12 ]
crash93ssei
228
14267
Wed Jul 29, 2009 10:27 pm
Ms. Sixty View the latest post
There are no new unread posts for this topic. 3800 Meet - June 13th 2015 - Royal Oak, Mi.
WhiteArrow3800
11
1641
Tue Dec 02, 2014 11:28 pm
There are no new unread posts for this topic. MN Krue! Summer meet?
3371
Wed Jul 18, 2012 12:39 am
ga93sle View the latest post
