It is currently Thu Feb 13, 2025 12:30 pm
PostPosted: Tue Jan 07, 2025 5:21 pm
Year and Trim: 2002 SSEI
Hey all, long time listener first time caller.
I bought this Bonneville in April 2024, and it's been a love / hate relationship. Loved it after having a test drive, but regretted my purchase when I discovered... Many problems. The list of things I've fixed is huge, but she still needs work. I was going to sell it, and the day before I made the deal, my other daily blew up. I'm glad I kept my bonnie! Been driving it and fell back in love, now I want to actually make her a solid vehicle. Thing is, I'm in the "great" white north (Canada) and we're about to see a huge jump in prices for car parts and really anything that comes from our southern neighbor, so I'm just trying to get a list together fast to prepare, IF it's worth it. Just want a second opinion. Currently has 230k KM / 142k MI on the odo. Now where to start...
She's loose. I did replace front tie rod ends, front hubs and brakes, right CV axle and both sway bar links before getting an alignment. But when I hit the highway, the grooves in our worn out roads pull me around like crazy, like a ship in choppy water, double handing the wheel for sure. When I hit the brakes in a bend, I get a moderate front end vibration. I'm guessing bushings? Would love to see if there's a way I can tighten her up and gain a bit more confidence in the bends.
Needs total overhaul of trans / motor mounts. Shifts good (most of the time) since I put the Transgo shift kit in but I sure feel the sloppy-ness of the mounts. Exhaust leak getting quite loud from the rear manifold (I think) and the CAT is blown out. It stinks after driving for a bit, not sure if it's a cat smell, but it smells a bit like rubber.. No clue.
Tons of water leaks but I've seen the threads on how to fix those, just need the weather to get a bit better. Sunroof is bound and leaking, trunk leaks, door leaks, etc.. Driver's door only opens from the inside.
Service air bag and service theft system lights are both illuminated intermittently.
It's cosmetically cooked. Clearcoat is done on the roof, hood and trunk. Full of scratches. Not much hope in fixing that without a paint job..
All the lenses are done for, I know those are a pain to get a hold of too.
Some repairs I've done: Radiator + hoses, coolant elbows, rotors and pads all round, front end stuff^, rear widow motors/regs, shift kit, most vacuum lines done, PCV valve, full service (eng, trans, s/c)
I can go on. Is this worth it? I feel like I have to keep going since I'm so deep already but man, it's a lot. I also have no back up vehicle. Any advice is greatly appreciated, even if it's telling me I'm a clown!
PostPosted: Wed Jan 08, 2025 1:30 pm
Year and Trim: 2003 SSEi
For most of your mechanical stuff, can't you just get that from someplace like RockAuto? For everything else, go to Bonnevilles Unlimited. Andrew (harofreak00) can source pretty much anything you need for 00+ Bonnevilles.
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Wed Jan 08, 2025 3:20 pm
Yeah I'm a devoted Rockauto Customer, I'm just trying to save myself from the massive increase of prices coming next month by pre-emptively ordering as much as I can. Figured perhaps a fellow enthusiast had some suggestions as to what I should focus on, or maybe something I might not have known about :canada:
Just gonna keep reading these forums, I'll probably end up ordering more than I need just in case... The fan is about to be hit up here if ya know what I mean! Cheers
There are no new unread posts for this topic. my project spl car. 2000 SSEI
bigshay
Thu Sep 18, 2008 7:23 am
95SLE View the latest post
There are no new unread posts for this topic. Hello from a guy with an unusual project in the works.
MAX_118
Wed Sep 15, 2021 8:51 pm
95naSTA View the latest post
There are no new unread posts for this topic. Project New Zealand - ('65 Bonneville re-build)
Kiwi Slip
Fri Jul 17, 2009 10:56 pm
Kiwi Slip View the latest post
There are no new unread posts for this topic. Hello everybody! New here with an 01 SSEi!
Loaded87IROCZ
Mon Jun 10, 2013 11:10 pm
BonnieBoy08 View the latest post
There are no new unread posts for this topic. 02 ssei
02ssei
Thu Mar 10, 2011 9:59 pm
