It is currently Wed Apr 24, 2019 7:44 pm
 Post subject: Expansion valve location
PostPosted: Mon Apr 23, 2018 2:12 pm
Year and Trim: 2005 Pontiac Bonneville 3.8 SE
Aloha from Hawaii! I have a 2005 Pontiac Bonneville 3.8. I can't seem to find the expansion valve for my a/c. Some call it the oriphis tube, but that's not what I'm looking for. Any photo or information of it's location would be gratefully appreciated!
PostPosted: Mon Apr 23, 2018 5:25 pm
There is no expansion valve. The oriphis tube is between the low and high side valves.
-Andrew-
PostPosted: Tue Apr 24, 2018 6:16 am
I appreciate your quick reply. When I check the low side it's at about 40 and the high side is about 200. Then the high side starts to up, but the low side does not adjust accordingly. This lead ne to believe that there is some type of blockage/ restriction. Am I on the right track?
PostPosted: Tue Apr 24, 2018 8:59 am
What is the actual problem with the system? Is it not cooling? Your numbers sound normal.
-Andrew-
PostPosted: Tue Apr 24, 2018 4:18 pm
The temperature in the car with a/c on gets cold, but not as cold since I changed the compressor. It was the reason I had changed the compressor since I had a new spare. It's just a little colder, but not where I think it could be/ use to be. It's in the range of 70-60 at the most.
PostPosted: Tue Apr 24, 2018 4:32 pm
Did you evacuate the system? How much freon did you put in?
-Andrew-
PostPosted: Tue Apr 24, 2018 9:22 pm
Evac was for about 45 minutes and about 2# of coolant. If there is no expansion valve, what converts the liquid to a vapor?
PostPosted: Wed Apr 25, 2018 9:11 am
The system performs much better with 2.5lbs, even though the manual states 2lbs. If you notice its cooler on the passenger side than the drivers side, that is a symptom of a low charge.
Here is a link with a simple explanation of the differences between a cycling clutch orifice tube system and a thermostatic expansion valve system.
https://www.freeasestudyguides.com/ac-ccot-vs-txv.html
-Andrew-
PostPosted: Wed Apr 25, 2018 10:17 pm
Thanks for taking the time and effort in linking me up with the site. I didn't know. I thought all vehicles with a/c had an expansion valve. I thought the orifice tube was only to filter out rubbish in the system. Thanks again.
PostPosted: Mon Apr 30, 2018 3:03 pm
I sure could use a diagram of the accumulator and which way the orifice tube faces. I found my orifice tube in the connecting side of the low side to accumulator.
PostPosted: Mon Apr 30, 2018 5:19 pm
I posted pics of those in your other thread but here:
here you go this is what GMSI shows for 05 model
https://drive.google.com/file/d/1KI4Tw3 ... sp=sharing
https://drive.google.com/file/d/1hzPCN4 ... sp=sharing
3.8L V6 SC, 180*T (Drilled),
PostPosted: Mon Apr 30, 2018 10:46 pm
When I go to these sites, I get this.
Sorry, the file you have requested does not exist.
Make sure that you have the correct URL and the file exists.
PostPosted: Tue May 01, 2018 12:24 pm
If it helps, this is what the instructions say: "Install the new expansion tube. Ensure that the short screen and arrow face toward the evaporator."
PostPosted: Tue May 01, 2018 4:41 pm
My accumulator is under the hood. One line going in and the other end is where the orifice tube goes. That line goes into the firewall. Hate NAPA guy told me the short side of the tube faces towards the accumulator faxing the front of the car. I'm confused.
PostPosted: Tue May 01, 2018 8:28 pm
Code:
https://drive.google.com/file/d/1hzPCN45IfH22VIi5qFtZrymUEWCA0Voc/view?usp=sharing
Code:
https://drive.google.com/file/d/1KI4Tw3gjg986SDHeFGtl-rZo9KBOCl_Q/view?usp=sharing
try copying and pasting those.
PostPosted: Tue May 01, 2018 11:19 pm
Thanks a million! It's exactly what I was looking for. Now I get it. I cannot tell you how grateful I am! Thanks again!
There are no new unread posts for this topic. Try to find engine drain plug for coolant. what location?
1Bonnie&clyde1
Mon May 25, 2015 11:13 pm
haro1225 View the latest post
This topic is locked, you cannot edit posts or make further replies. Try to find engine drain plug for coolant. what location?
1Bonnie&clyde1
Tue May 26, 2015 10:35 am
