It is currently Fri Jul 23, 2021 2:41 pm
PostPosted: Tue Oct 20, 2020 9:45 pm
Year and Trim: 2004 GXP
Formerly known around here as BigErik.
I’m thinking of digging up a 92-93 Olds Touring Sedan with the Series 1 L67. Was just curious how they are aging now. Are parts available for them? Have there been any age related issues coming up that are making them undrivable? I’d appreciate your thoughts!
PostPosted: Tue Oct 20, 2020 10:49 pm
I would think random body and interior bits would be your biggest issue at this point, assuming a rust free car.
PostPosted: Tue Oct 20, 2020 11:27 pm
That isn’t discouraging! My plan is to find as nice a Touring Sedan as there is in existence. Likely a rust free, southern car. It’s only gonna be a weekend toy anyway. Just seeing the problems the C5 guys are starting to run into with failing, unobtanium electronic parts, make me leery of 90s electronics.
PostPosted: Wed Oct 21, 2020 9:56 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Electronics and almost everything interior is a safe bet you're going to have that issue with any 90's car. A good way to check is to see if RockAuto has parts available.
For the most part the C and H body cars have the major parts available still. If the touring sedan had a stiffer suspension or something like CCR shock/struts then you're not going to find them anymore.
L67 Cavalier
PostPosted: Wed Oct 21, 2020 10:58 am
The Touring Sedan is basically Oldsmobiles SSEi. So all the mechanical stuff should transition over easily. Easily, in the there were a lot more SSEi’s built then Touring Sedans. The touring sedan did get the higher level interior, with better materials, special Lear Siegler made seats, real burl walnut, etc. Kinda Oldsmobiles Jaguar.
PostPosted: Thu Oct 22, 2020 1:29 am
The one nice thing about 90s cars is no CAN Bus stuff, BCMs that need programming, etc. Current draws and other issues are easier to diag.
At this point the better the metal on the car you get is, the more the interior/exterior plastics/rubber got baked and dried out from either the sun or just time. You would be surprised how much of that stuff there is and will be NLA. I mean, the 90s was probably the peak of GM using plastics in interiors. It sounds like an Olds touring will be even more of a pain than a Bonneville too.
Just 2 of many examples..
Need to do a headliner? You'll be lucky not to damage it on the way out, you'll break a couple of the grab handles, the A&C pillar clips will break and the sun visor or dome plastics might not make it.
Need to repaint the car? Good luck finding all the clips, drip trim and misc. bits.
I'm obviously dealing with this stuff but I've accumulated a a small arsenal of spare parts over the years.
PostPosted: Fri Oct 23, 2020 12:09 am
Definitely all of those things are a pain, but they are things that can be worked around. A dead, unobtanium ECM, for instance, could turn a 90s car into a lawn ornament in a hurry. That’s the kinda stuff I’m worried about first.
Point well taken on what southern cars do to rubber and pieces. I suppose what I want is a garage kept, northern car, that was parked every winter. Shouldn’t be too hard to find. :)
There are no new unread posts for this topic. exhaust ports series 1 vs. series 2
MattStrike
Tue Feb 10, 2015 6:10 pm
Z-type View the latest post
There are no new unread posts for this topic. Batteries 78 series (92-99) vs 100 series (00-05)
1oldman
Sat Jun 14, 2014 7:08 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Series 2 vs Series 3 3.8L engine
bshar489
Fri Aug 05, 2011 10:38 am
There are no new unread posts for this topic. Series 2 to Series 3 swap
RoddyEvans
Fri Oct 20, 2017 10:44 pm
kc9dre View the latest post
There are no new unread posts for this topic. CompNine - GM Parts diagrams & Parts supplier
16940
Fri Nov 11, 2011 10:09 am
Ken_W View the latest post
cron
