It is currently Tue Aug 11, 2020 8:47 pm
 Post subject: Mods For Series I L27
PostPosted: Sat Jul 04, 2020 10:13 pm
Year and Trim: 1992 Buick Lesabre
Just recently bought a 92 Buick Lesbare not knowing that there is not much of a modding scene for the Series I. I would still like to do some mods would like to stay NA. I have a budget of around 500. Trying to get another 20-30 hp out of it. Was thinking of doing a cam but cannot find one anywhere for the series 1 do the series 2 cams fit in series 1? Any input is appreciated. I am not going to swap it for the series II because I don't have enough free time to do so and this is my daily.
PostPosted: Sun Jul 05, 2020 10:38 am
Talk to Crow Cams. They are out of Australia, where the mod market for the Series 1 was stronger. They have a different name for the engine, so you have to explain carefully.
PostPosted: Mon Jul 06, 2020 6:55 pm
20-30 horsepower will be nearly impossible with that budget much less being NA.
Start with a different platform.
"Penelope" - 2003 SLE - 210k Miles
"Sydney" - 2000 Honda S2000 - 76k miles
PostPosted: Tue Jul 07, 2020 11:51 am
Depending on your ability and you-pull-it junkyard options, you could probably swap in a L36 and get a custom tune for $500. That would reliably push the car into the later half of the 90s at least. A Series 1 or 2 L67 wouldn't cost much more but the transmission wouldn't last. If you have to pay to have the work done, quadruple the price.
07 Infiniti G35s 6MT
PostPosted: Tue Jul 07, 2020 10:02 pm
Unfortunately, the above posts are just about it.
Custom cold air intake and high flow cat will free it up a bit for pretty cheap. Porting and polishing will put a bit of pep in its step as well. There were some rockers that would fit series 1, but only the 94-95 heads if memory serves (bolt sizing different).
The bottom end can't take much more.
PostPosted: Tue Jul 07, 2020 10:16 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I would find an entire series 1 L67 donor from a park avenue or bonneville and swap everything over - it's stock, it's reliable, and it's way more power than $500 will get you on the N/A setup. You might have to verify the pins on the connector under the dash for the engine/pcm harness match, but it's mostly a drop in swap (complete engine/trans/harness/ecm), and you might be able to find a donor in the $400 range. That's what I did with our '93 SE way back in the day. Was done in a busy weekend.
Other options are to find a junkyard turbo if you have a MIG welder, upgrade the pcm to the 98+ 3800 one to make tuning easier. Again, a lot of work on you to pull it off, but if you're thrifty it could be done in the $500 or so budget. 5psi would give you a nice boost in power, but the trans is probably not going to be happy.
upkeep on K2500 and 97 LeSabre
There are no new unread posts for this topic. exhaust ports series 1 vs. series 2
MattStrike
Tue Feb 10, 2015 6:10 pm
Z-type View the latest post
There are no new unread posts for this topic. Series 2 vs Series 3 3.8L engine
bshar489
Fri Aug 05, 2011 10:38 am
There are no new unread posts for this topic. Batteries 78 series (92-99) vs 100 series (00-05)
1oldman
Sat Jun 14, 2014 7:08 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Series 2 to Series 3 swap
RoddyEvans
Fri Oct 20, 2017 10:44 pm
kc9dre View the latest post
This topic is locked, you cannot edit posts or make further replies. Mods to Run E85?
[ Go to pageGo to page: 1 ... 4, 5, 6 ]
SacramentoE85
119
17664
Tue Sep 16, 2008 10:22 am
BlackHawk99 View the latest post
