It is currently Wed Jul 15, 2020 6:28 am
PostPosted: Thu Oct 03, 2019 5:15 am
Year and Trim: 1992 Pontiac Bonneville ssei
I am reaching out to the forum today
In the vehicle I recently bought there seems to be an aftermarket system installed you turn the key to the run position and push a giant button on the dash to start the car I personally don't like it looking for more information on this
As well my radio doesn't keep its presets
because coming out of that 15 amp plug is two wires the wires are fused afterwards but I can't exactly figure out where they go it appears that one of them might go to the starter but I don't know I'll attach some pictures
Hopefully this work here's a link
My 92 Pontiac Bonneville https://imgur.com/gallery/uu6ZzT5
PostPosted: Thu Oct 03, 2019 10:23 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Sounds like somebody who didn't know anything about wiring diagnostics bypassed something to make the starter work...
First thing you need to do is get ahold of the wiring schematic for the starting circuit and radio circuits. Delete all that crap and put a fuse back into #11 to fix the radio issue. Then figure out what failed in the starting circuit. Use a voltmeter to find out what component isn't working and fix it. Start with +12v to the ignition switch, +12v out of it during cranking, I think it goes through the neutral safety switch next, and finally to the starter.
PostPosted: Thu Oct 03, 2019 4:34 pm
Thanks I will but from my quick testing the other day it would still start with a feuse in 11 and thoes wires out
Will take some work but I intend to remove the button and add remote start cause I have one laying around hopefully won't be to hard
She needs a bit of love but for 800 I can't complain
PostPosted: Thu Oct 03, 2019 4:45 pm
Also I'm thinking of getting the repair book From Haynes
Are they still the best option I got one for my truck but is there better out there I see the service manual from gm
https://rover.ebay.com/rover/0/0/0?mpre ... 1691995489
Does anybody know if that will have it all
PostPosted: Fri Oct 04, 2019 9:34 am
'05 STS-4
'97 LeSabre
The service manual from GM is the best manual you can buy. It has everything in it.
PostPosted: Fri Oct 04, 2019 5:33 pm
Thanks I was thinking of just grabbing it the 3-pack it's not that expensive
Thanks for your advice
Today's plan that the battery charge after being jump-started and take it to her Canadian store called Canadian Tire
That chain is stores will test a battery for free so I can eliminate whether or not I got a crap battery draining
In that photo there's the two leads coming out of it for now couldn't I just shove a 15 amp fuse in over top of those wires until I get a chance to figure out what the hell is going on
There are no new unread posts for this topic. Bonneville wouldn't start?!
SSEimatt93
Tue Jan 17, 2012 8:52 pm
SSEimatt93 View the latest post
There are no new unread posts for this topic. 2005 Bonneville gxp won't start electric problem help!!!
Bluebonnie05
Thu Jun 30, 2016 12:25 am
There are no new unread posts for this topic. Start issue
1sik ssei
Wed Jan 02, 2013 11:49 pm
There are no new unread posts for this topic. Start with the IAC? ('02 Regal)
Bumzag
Fri Nov 20, 2015 1:45 pm
Bumzag View the latest post
There are no new unread posts for this topic. Did Bonnevilles ever come with OEM remote start?
phil0054
Wed Mar 06, 2013 9:19 am
