It is currently Wed Aug 12, 2020 9:25 pm
 Post subject: The time has come....
PostPosted: Sun Aug 18, 2019 7:57 pm
Year and Trim: 2002 SE, 2013 Regal GS
I knew this moment would come sooner or later, but not this soon.
It is time for me to get rid of my Bonneville.
I'm always gonna be grateful for how reliable she has been over the last (almost) 6 years. Sure, there might've been a problem here or there, but it was just about always a DIY job to solve the issue. But, alas, the car gave me 2 issues that are too expensive to repair, considering the age and condition of the car.
I thank those on this forum (past and present members) for the advice and knowledge I've been able to gain from this forum. It has been extremely helpful, and I'm extremely grateful.
I couldn't have had a better first car.
'13 Buick Regal GS 69k miles (nice), 270 hp, 295 lb/ft of torque.
PostPosted: Sun Aug 18, 2019 10:07 pm
What ended up happening?
"Penelope" - 2003 SLE - 210k Miles
"Sydney" - 2000 Honda S2000 - 76k miles
PostPosted: Mon Aug 19, 2019 3:27 pm
Fuel filter was leaking a tiny bit of gas. My shop (rather hastily) claimed that since the fuel filter is original, they risk the possibility of breaking the fuel lines, therefore having to replace the fuel lines. I'd rather just avoid the hassle.
Another small problem is the headliner starting to sag in random spots.
I still have the car, but not for much longer.
PostPosted: Tue Aug 20, 2019 5:26 am
The headliner is a DIY fix. Lots of members have recovered them. I can't help but think there's got to be more to the story. I just don't see the fuel line, if it does turn out to be a problem, a reason to give up on the car.
PostPosted: Tue Aug 20, 2019 8:26 am
fuel filter can be cut out and use unions to repair lines - 1 - 2 hour job
PostPosted: Tue Aug 20, 2019 2:44 pm
I was just going to say, fuel filter could've been cut out, fixed/flared and new filter put in.
Now if the rest of the line is in terrible shape... Different story altogether.
PostPosted: Wed Aug 21, 2019 3:27 pm
I'd spray the *shoot* out of that fuel filter with PB blaster and carefully remove it.
PostPosted: Fri Aug 23, 2019 8:32 am
They've been telling me for the last, I don't know, 4 years that my fuel lines were starting to go out. Specifically, rust. I've seen it myself, but it isn't as bad as they make it seem. DIY-ing the fuel filter doesn't sound like a job I should do.
Even then, the undercarriage of the car is starting to get pretty bad in the areas I've listed before on here (right below the driver's feet). Not to mention the bondo job I tried to do underneath the fuel filler door, as well as a coolant leak I have - which in order to fix that, I'd have to get the LIM gasket replaced. Rust is also starting to poke its annoying head out in different areas, such as on the inside of the front fenders, bottom of the doors, etc.
PostPosted: Fri Aug 23, 2019 10:23 am
That paints a little clearer picture of things. To be honest, I don't think I've read previous posts about the condition of your car. So, based on your initial post in this thread, things really didn't sound too bad (as long as those were the only two issues). Unfortunately, it appears there's a lot more going on. I'd probably be reluctant to put much money into the car either.
PostPosted: Fri Aug 23, 2019 10:52 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
In my mind, the condition of the car makes it the perfect reason to fix the two main problems, and keep it as the winter beater so the new car doesn't have to get all salty.
But that's hard to do if you don't have the tools, time, or ability to keep it going yourself. Sad to see another one go, but you have to do what works for you.
upkeep on K2500 and 97 LeSabre
PostPosted: Sun Aug 25, 2019 11:09 am
I haven't really been descriptive about the issues with my Bonneville because they haven't really been happening that fast, but they've been happening slowly over time (specifically with the rust on the undercarriage). Since I've been done with college, I've had more time to take a look at the car, and just see how much has happened.
Normally, I'd usually post something if I had a basic question or if something weird is happening (such as a misfire that *can* happen upon start-up due to my slow coolant leak from the outside of the LIM gasket).
PostPosted: Sun Aug 25, 2019 11:16 am
I always told myself when I first got the car that I was going to "drive it until it dies" or "I won't let it rust to death". Interesting how priorities change over time.
If the rust wasn't getting to the point it has gotten to, I'd fix the fuel filter/line and still drive it. I have enough money to use for that kind of repair. It just gets to a point where it is pointless to put more money into it if more problems will arise soon after a repair. I don't really have the time to take out a day or two to fix the headliner myself, or do any other extensive job on the car, as I work 2 jobs.
There are no new unread posts for this topic. When is it time to let go?
LeSabreUltra
20
2439
Fri Apr 23, 2010 2:13 pm
LeSabreUltra View the latest post
There are no new unread posts for this topic. I think it's time for the GXP to go.
donky4444
Thu Apr 29, 2010 2:27 am
viper8907 View the latest post
There are no new unread posts for this topic. MPG time
2367
Mon Jul 28, 2008 8:01 am
BlackHawk99 View the latest post
There are no new unread posts for this topic. It's that time.
Maymybonneliveforevr
12
1551
Sat May 18, 2013 1:33 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. The Time Has Come
Radix4257
Sun Aug 19, 2018 1:07 pm
Radix4257 View the latest post
