It is currently Wed Feb 26, 2020 12:23 pm
PostPosted: Tue Apr 30, 2019 12:51 pm
Year and Trim: '02 Bonneville SSEI
Looking for directions for removal ECBM on 02 Bonneville, seems to be a limited subject.
Thanks for the photo showing correct location on "02. u know who u r.
PostPosted: Tue Apr 30, 2019 2:34 pm
I've attached the FSM instructions, but basically you just remove the front left wheel and wheelwell plastic and you have full access. Disconnect the wiring and remove the 6 T20 torx screws. Don't be surprised if 1 or 2 screws shear off, happens all the time. If 3 or more shear, you are in trouble. Take it easy on them. Use a flat blade screwdriver to pry them apart, starting from the bottom. The silicon used to seal them up will make the two halves hard to separate. Take it easy on this also. Try not to mar up the silicon seal.
Quote:
Electronic Brake Control Module (EBCM) Replacement
Removal Procedure
1. Turn OFF the ignition.
2. Raise the vehicle.
3. Remove the left front wheel.
4. Remove the left front wheelhouse extension.
5. Thoroughly wash all contaminants from around the EBCM.
6. Rotate the EBCM connector tab up to the unlocked position.
7. Remove the EBCM connector position assurance (2) from the EBCM electrical connector (1).
8. Disconnect the EBCM electrical connector (1) from the EBCM (4).
9. Disconnect the brake pressure modulator valve (BPMV) electrical connector (2) from the EBCM (3).
10. Remove the 6 EBCM to BPMV screws (2). T20 torx
11. Clean the surface of the EBCM/BPMV assembly.
12. Separate the EBCM (2) from the BPMV (1).
Installation Procedure
1. Clean the seal surface of the BPMV.
2. Install the EBCM (2) to the BPMV (1).
3. Install the 6 EBCM to BPMV screws (2). Tighten the 6 screws to 3.2 N·m (28 lb in).
4. Connect the BPMV electrical connector (2) to the EBCM (3).
5. Connect the EBCM electrical connector (1) to the EBCM (4).
6. Install the EBCM connector position assurance (2) to the EBCM electrical connector (1).
7. Rotate the EBCM connector tab (2) down to the locked position.
8. Install the left front wheelhouse extension.
9. Install the left front wheel.
10. Lower the vehicle.
11. If a replacement EBCM is being installed, it must be programmed using the latest software matching the vehicle.
12. Use the scan tool in order to clear the DTCs.
13. Perform the ABS Diagnostic System Check. Refer to Diagnostic System Check - Vehicle in Vehicle Control Systems.
EBCM replacement.pdf [105.84 KiB]
Downloaded 54 times
-Andrew-
PostPosted: Tue Apr 30, 2019 3:37 pm
As long as you're gentle, this is a pretty quick job! Just be patient with all the old stuff like Andrew said above.
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Tue Apr 30, 2019 4:29 pm
Thanx 2 harofreak00,
appreciate word for word as well as diagrams.
There are no new unread posts for this topic. DIY BLOWER MOTOR CONTROL MODULE
gmman
Sun Jul 31, 2011 11:40 am
gmman View the latest post
There are no new unread posts for this topic. Ignition Control Module (ICM) 2001 Bonneville
dougtoth
Sun Sep 20, 2015 10:15 pm
dougtoth View the latest post
There are no new unread posts for this topic. 94 SE Multi Function Chime Control Module
jp0451
Sun Aug 28, 2016 9:05 pm
RJolly87 View the latest post
There are no new unread posts for this topic. Does the door module's control the heated seats function ?
SPLLOUDER
Thu Dec 13, 2012 12:54 am
There are no new unread posts for this topic. A/C Heater Programmer Module
Radix4257
Sun Aug 12, 2018 2:45 pm
Radix4257 View the latest post
