It is currently Sat May 25, 2019 5:00 am
 Post subject: Odd 4t65 issue
PostPosted: Thu Feb 14, 2019 11:21 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
in my '97 Lesabre 'l67 swap turned top swap'. Pulled from a 1998 Olds, unknown mileage, high enough that the 4th hub was on it's last leg.
Things it has:
hardened 4th hub
DIY shift kit
upgraded channel gaskets for the cover
And that's about it. No funky smells from the fluid, when I dropped the pan to change something in the shift kit I didn't see anything abnormal.
What it's doing:
When you get to the shift point, it feels like something is starting to happen, like power isn't quite reaching the wheels, but it takes over a full second for it to actually shift. When it does, it shifts like it has a shift kit. It does this on the 1-2, and the 2-3, and I think the 3-4. Thus far, I really haven't driven very far as the darn coolant elbow was leaking, and it need gas, etc, so I can't verify TCC lockup.
Kickdowns are instant, and it doesn't slip at all, WOT feels strong like you'd expect, aside from delayed shifts.
We messed around with the tune a bit, but it's definitely not that. At this point, I'm leaning toward something mechanical, or maybe it's something to do with the pressure switches, pcs, or shift solenoids? I was going to try and find the hydraulic diagrams that are not in any of my various CSMs. I don't have a tech 2 to do any scanning with, but I do have access to a DHP
All the engine sensors are working, the only check engine code is for the EVAP solenoid that I haven't extended the wires for (yet, doing that this weekend lol). I double checked the TPS, my scanguage is telling me it's working correctly and the DMM shows no dead spots.
My next diagnostic step is to follow the component resistance check procedure, just to see if I can rule anything out there. But I guess if I don't come up with anything I'm just going to drive it as is for a while, until the weather is mild again and swap in the other trans I have.
Any other thoughts or ideas?
Runs:
Doesn't run:
 Post subject: Re: Odd 4t65 issue
PostPosted: Fri Feb 15, 2019 1:52 pm
'05 STS-4
'97 LeSabre
OK, managed to find a PDF of the GM technicians manual for the 4t65. It looks like shifting on the 4t65e is really simple...
1-2 upshift
1. PCM turns off the 1-2 solenoid, which exhausts the 1-2 and 3-4 hydraulic signal
2. Spring pressure in the shift valve moves the valve to the upshifted position, sending fluid into the appropriate path
3. #2 check ball seats
4. hydraulic pressure applies the 2nd clutch.
2-3 upshift
1. PCM turns off the 2-3 shift solenoid, which exhausts the 2-3 hydraulic signal
2. Spring pressure moves the valve to the upshift position
3. #9 check ball seats
4. #4 check ball seats
5. Third clutch applies
and so on...
It looks like any kind of fluid pressure drop would result in either a slow shift or slipping. Bad solenoids result in a complete loss of a gear.
So at this point I'm guessing that there's either clogging in the shift solenoids so they can't exhaust properly, or the valves themselves are sticking slightly. But even that seems odd, how could both of them have the same issue?
Runs:
Doesn't run:
PostPosted: Fri Feb 15, 2019 4:31 pm
Year and Trim: 99 Regal GS
PCS or pressure switches going out?
1999 Buick Regal GS 3.4" pulley,SLP headers, fwi, pnp, gemini chain w/ other trans mods, 12" brakes, GR2's, STB's, 34mm front sway bar; The Summer DD
1982 Pontiac Grand Prix L36 and an hx35 turbo; It's pretty quick Mod list here
PostPosted: Fri Feb 15, 2019 11:30 pm
It's not torque management, is it? Or possibly false KR?
That's how I would have described my friends 2016 Sierra before it got a tune, like the computer was backing of power or slipping a clutch surrounding a shift.
PostPosted: Mon Feb 18, 2019 10:56 am
'05 STS-4
'97 LeSabre
Welp, this weekends recent events mean that I'm going to be putting the built up trans back in this car before I start driving it for the year. So if the other trans still does this then we'll know it wasn't the trans.
Runs:
Doesn't run:
There are no new unread posts for this topic. Another 4T65 Down
Jfridge92
Sat Dec 23, 2017 9:31 pm
Roadrunner View the latest post
There are no new unread posts for this topic. 4T65, Dex-VI, and the DIY Shift Kit
LeSabre in Buffalo
Tue Nov 03, 2009 7:13 pm
There are no new unread posts for this topic. 4t65 issues...
MattStrike
Sat Dec 23, 2017 12:37 am
There are no new unread posts for this topic. 4T60 & 4T65
WhiteArrow3800
Fri Aug 14, 2009 3:52 pm
There are no new unread posts for this topic. What is it with the 4T65 shudder problems?
LeSabre in Buffalo
17
3171
Fri Mar 19, 2010 8:21 pm
LeSabreUltra View the latest post
Users browsing this forum: Exabot [Bot] and 4 guests
