It is currently Tue Feb 19, 2019 10:28 am
PostPosted: Tue Feb 05, 2019 11:11 am
Year and Trim: 2003 sle
I have a 2003 sle. About a week ago I put a shift kit in due to a slight slip. Everything there worked out great. Shortly after my airbag light would occasionally flash. Then a few days later my power locks would quit working sometimes. Then finally the other day the gauge panel was dead. I shut off the car and tried to restart it and the key wouldn’t start the car. My buddy showed up with his trailer. In the process of pulling the car on the power locks tripped off. I turned the key and the car started right up. Without gauges I drove it home and let it run for 20 minutes. Shut it off and now it won’t start. Sometimes when I try to start it the alarm will go off. I have no interior lights and the windows and locks do not work. The power seats work. It has had an aftermarket radio in it for well over 4 months. Does anyone have any ideas for me? Or is there already a page for this I’m not seeing? I’m new here and just want to drive my car again...any help is greatly appreciated. Hate having it sit always loved these cars.
PostPosted: Wed Feb 06, 2019 12:39 pm
Sounds like you may have a loose ground somewhere.
PostPosted: Wed Feb 06, 2019 12:59 pm
I'd suggest checking power and ground around the main connections. Check battery condition, the connections on the battery, remove the cable from the negative battery terminal at the floor pan. Clean up any rust or corrosion. Also, check the power cable at the underhood fuse block.
There are no new unread posts for this topic. ECC 2003 SE?
1oldman
Fri Oct 30, 2015 2:57 pm
gtpstyl View the latest post
There are no new unread posts for this topic. 2003 SSII
tanderson
11
1940
Sun Jun 01, 2008 12:49 am
radomirthegreat View the latest post
There are no new unread posts for this topic. 2003 ssei vs 99 sle
deano55
25
2787
Sat Mar 03, 2012 11:42 am
deano55 View the latest post
There are no new unread posts for this topic. 2002 or 2003? not sure
YoungBonne12
Thu Nov 17, 2011 11:29 pm
There are no new unread posts for this topic. No crank 2003 bonneville
jbac06
Mon Aug 19, 2013 6:18 pm
jbac06 View the latest post
