It is currently Sat Jun 06, 2020 2:10 pm
 Post subject: L67 swap
PostPosted: Tue Oct 30, 2018 10:39 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I know, I know, I have a problem...
I'm planning to L67 swap (or top swap) the Trofeo. But looks like there might be a bit of a snag. The Trofeo, being years ahead of it's own technology, uses the serial data line to share information from the PCM and BCM to the IPC.
Basically, from what I remember from my OBD-1 days, each PCM would transmit data on the serial bus in a specific format, and that format varied from vehicle to vehicle. In either case, it sounds like if I want to keep the cluster and digital display functional, it sounds like my PCM options are extremely limited to the one that's already in there. So no OBD-2, can't use the '93 SSEi PCM, etc.
I've found a single cryptic reference to somebody that had done it on an '89 or something like that. I'm still researching, cars like the Reatta and Riviera from this generation would run into a similar issue I'd think. So if any of you that still use the forums can recall one of these builds to give me something to go by, I'd appreciate it.
The original idea/plan for this build was to use the '93 L67 drivetrain I have, and either convert it to OBD-2 or use the '93 SSEi PCM. But none of the inputs to for the cluster gauges (except the tach) are analog.
 Post subject: Re: L67 swap
PostPosted: Tue Oct 30, 2018 1:19 pm
'05 STS-4
'97 LeSabre
OK, a few builds I've managed to find thus far.
1st: LN3 top swap (kept the original computer and had a custom PROM burned)
http://forums.aaca.org/topic/79774-supe ... -its-real/
2nd: Series one swap and then series 2 swap. Looks like again, had the existing PCM tuned to work:
http://www.theautoshop.net/SuperchargedTrofeo.htm
Looks like people have been getting their OBD-1 PCMs tuned to work with the L67. I don't want to do that, but it's looking like it's basically the only option if I want to keep the electronics in the vehicle functional.
I'm thinking the only other way around this is to piggyback the Olds ECM, let it read the various sensors and think it's doing something, while the engine/trans are controlled by the OBD-2 PCM. I'd have to check all the wiring diagrams, I doubt I could get some functions to work correctly (fuel econ for example) but at least the dash wouldn't be hacked and/or loss of all functionality. But I'd have a far superior PCM.
PostPosted: Tue Oct 30, 2018 9:52 pm
Does tunerCATs support it?
I wrote a guide on tuning OBD1 before but I think it got lost in the forum shifts. It's really not that bad.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Wed Oct 31, 2018 7:19 pm
So I found a post I made 10 years ago on w-body.com for the LQ1 but it might help:
https://www.w-body.com/topic/34441-obd1 ... ent-563549
05 Suzuki DRZ400S
PostPosted: Wed Oct 31, 2018 10:57 pm
I have seen people do insane things with Raspberry Pi's these days, and part of me wonder if something of the like can be set up to interface with your cluster.
PostPosted: Thu Nov 01, 2018 10:59 am
'05 STS-4
'97 LeSabre
I have thought about getting into OBD-1 tuning a lot over the last 15 years. I just didn't really know what I was doing, and back then the cost was too much. A quick glance at tunercat doesn't seem to have anything for the '92 toronado but I should probably do some real research there.
The problem with the raspberry pi thing is I have no idea where to even begin with that.
PostPosted: Thu Nov 01, 2018 11:11 pm
So it's probably a 27C256 and you could probably run it off a L27 bin. I just don't know what that means for all the interface gizmos if anything at all.
I tune from a 94 L27 bin that I imported most of the L36 tables into. I also tune on the fly using an eprom emulator.
05 Suzuki DRZ400S
PostPosted: Fri Nov 02, 2018 9:55 am
'05 STS-4
'97 LeSabre
Yeah, I'd have to look into it, but what I think happens is that the ECM operates in some kind of 'data out' mode - perhaps the ALDL cover has a resistor jumpered pins to enable that - and the IPC looks for that message and just reads the data sent. The ECM OS should handle all of that separately from the actual tune.
Another thought, again my knowledge here is very limited, is could I take the PROM out of the '93 SSEi ECM and would it plug and play with the '92 Toronado ECM?
The last time I really did anything with these things was with the '86-'87 LG3 stuff, so my memory might be missing a few details. I had a crapload of different PROMs I'd grabbed out of salvage yards from basically every different computer/configuration that motor was used (Rivieras, Toronados, Cutlass Ciera, etc...) I had even grabbed most of the CRT system, and it's matching ECM/PCM from an '87 LG3 car (that I never got around to finishing), all in an attempt to diagnose why that motor never ran right. Of course, I kinda gave up with that and L67 swapped. But I thought I remembered that the PROMs were interchangeable. I'll have to check the Olds ECM and the CSM to see if there's any insight there.
PostPosted: Fri Nov 02, 2018 1:48 pm
So the proms might be the same but the whole removable MEMCAL (memory calibration) chip might be different with a different socket at the PCM board. PROMS are sometimes soldered under the calibration chip on the MEMCAL. The w-body link gives an example of an adapter that lets you plug the memcal into it, has a socket for a PROM/EPROM and only connects the calibration chip portion of the MEMCAL. That way you don't have to relocate the cal chip to the bottom and solder in a socket.
05 Suzuki DRZ400S
There are no new unread posts for this topic. Swap an L26 for an L27?
1oldman
11
1539
Sun Feb 13, 2011 12:27 am
There are no new unread posts for this topic. HUD and ECC swap into '02 SE
crash93ssei
Thu Apr 25, 2013 12:13 pm
sandrock View the latest post
There are no new unread posts for this topic. L36 to L67 swap
christopner101
Wed Aug 31, 2016 11:06 am
There are no new unread posts for this topic. LS4 Swap
99BonnevilleSE
Wed Aug 10, 2011 10:31 am
Jrs3800 View the latest post
There are no new unread posts for this topic. 92/93 L67 swap into 94/95 L67 car
olblueeyesbonne
Fri Oct 18, 2013 12:34 pm
olblueeyesbonne View the latest post
