It is currently Sat Oct 24, 2020 9:51 pm
PostPosted: Thu Oct 25, 2018 11:03 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Does anybody know what size or have a part number for the oring on the top vacuum tee on the M90's? Mine is stretched and cut apparently...
upkeep on K2500 and 97 LeSabre
PostPosted: Thu Oct 25, 2018 11:36 am
'05 STS-4
'97 LeSabre
Found the OE part number: 24503492 O-RING SEAL-0.864
It's discontinued. Still searching for what size it is..
PostPosted: Thu Oct 25, 2018 12:38 pm
This site indicates that they have it in stock, as well as giving the dimensions.
http://oemcats.com/oem-parts/24503492.html
PostPosted: Thu Oct 25, 2018 12:45 pm
They are always stretched out. I tried a couple different ones from my standard o-ring kit and got one to work. I'm assuming you have the vacuum tree, just grab some and start test fitting...
-Andrew-
PostPosted: Fri Oct 26, 2018 9:28 am
'05 STS-4
'97 LeSabre
I ended up with two different O-rings to try. The first is metric, 22mm ID x 2.5mm cross-section, the other standard 7/8 ID x 3/32 cross section - which is as close to the sizes listed in the link above I could find locally.
Both are a tight fit, need some grease to get the vac manifold installed again, but they work.
PostPosted: Thu Sep 10, 2020 10:17 pm
'05 STS-4
'97 LeSabre
I was searching for this again tonight, figured I would update this thread since it's one of the first google hits.
GM original part number is 24503492 - of course it's discontinued. The description is 0.864", other dimensions I could find are 0.1x1.1x1.1
The stretched out O-ring measures close enough that 0.1" is the cross section (2.54mm). Since it's stretched out, the original cross section would have been slightly thicker than this (0.103/2.62mm is the actual measurement of the "0.1/2.5mm" standard).
The vacuum tee OD (the seal ID fit) is 0.868" (22mm). The hole in the supercharger case is 1". The supercharger is a counterbored hole, 0.377" deep (9.6mm). The shoulder on the vac tee is 0.232" deep (5.9mm)
Based on the measurements, this is an axial seal oring with 10% compression. The closest standard size is -118 (7/8 ID, 1-1/16" OD, 3/32" CS).
Since this is a vacuum tee oring, it only has to seal against air and moisture and heat, right? Wrong, that's why they are stretching out like hell. The oring appears to be EPDM - I say that based on results, since there doesn't appear to be an industry standard for colorant in the material. Usually, black=EPDM, brown=nitrile, green=HNBR, blue=Flourosilicone, but that doesn't apply to automotive where O-rings can be color coated as an assembly aid and to save cost no colorant added to the base stock, and the color coating can peel off or ooze out over time. Anyhow, EPDM is chemically incompatible with motor oil, which it is exposed to thanks to the PCV system, and swells (expands, stretches, etc) beyond usable. It's fair to note at this point that "chemically compatible" is relative and is graded on a scale. EPDM fits the symptoms. Also, when I say chemically compatible o-rings are HNBR, viton, and flourosilicone, I mean that they have less than 10% swell and are within the recommended temperature ranges.
There are no new unread posts for this topic. Discontinued vacuum tee alternatives
Backhoe
Sun Jul 28, 2019 7:30 am
LouF View the latest post
There are no new unread posts for this topic. Need Help Finding a Vacuum Hose Connector...
Blown93SSEi
Sun May 27, 2012 5:42 pm
There are no new unread posts for this topic. What controls vacuum on initial start and when AC is on?
Billha
Fri Sep 11, 2009 4:40 pm
J Wikoff View the latest post
There are no new unread posts for this topic. GM Part # For Fuel Pressure and EVAP vacuum harness
SPLLOUDER
Tue Jan 29, 2013 1:10 pm
Ken_W View the latest post
There are no new unread posts for this topic. DIY smoke machine - diagnose vacuum and evap leaks
Fri Oct 19, 2012 12:57 pm
Users browsing this forum: Google [Bot] and 10 guests
