It is currently Sun May 19, 2019 4:29 pm
 Post subject: service manuals...
PostPosted: Wed Oct 10, 2018 2:28 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
I've been double and triple checking the manuals on my '97 L67 swap ('98 engine harness), specifically for any differences in the Engine Controls section to identify what goes through the C101 pass-through.
Currently the fuel gauge doesn't work. I was able to find the wiring diagram for the '98 harness, shows the PCM connections for the fuel sender input and output. I found the PCM fuel sender input for the '97, but it doesn't mention an output for the '97. Thus far, the majority of the wires have been the same, with minor differences.
The differences I've found so far are:
-Need to confirm that a splice labelled S.929 loops C101 pins C1 and B4 on the body harness side. If not then need to add C1 to '98 harness and splice into B4 so the fuel tank pressure sensor works.
-No wiring diagrams for the 4t60 in this section - have to reference individual diagrams in the transmission section to know that there is a difference between the 4t60 and 4t65 wiring (now I don't feel as bad lol).
-Move body harness L3 pin to C3 (oil life reset switch for Buicks). The body harness with the L3 pin shouldn't have a wire in C3, but the '98 harness has a wire on L3, though nothing bad should happen if you press the button.
-C6 pin on the '97 harness is a IP fuse #5 +12v R/S for the EGR - it is not used on the '98 harness, giving you a free switched power source!
-Pin D7 on the '98 harness is the output from the PCM to the fuel gauge. I can't find the corresponding pin on the '97 harness (is it the same or different?)
I've checked the PCM connector end views in my '97 manuals - information there conflicts with information in the individual schematics - the '97 makes no mention of either fuel level input or output, and the '98 only mentions the input. And of course, while I can't really trust them at this point, I can't even find a connector end view with list by cavity for the C101 connector in either manual.
So, does anybody else have access to a (possibly better revision) '97 H-body manual that can check page 6E-21 for the fuel level output or know where I can find the '97 C101 end view and/or cavity list?
Runs:
Doesn't run:
 Post subject: Re: service manuals...
PostPosted: Thu Oct 11, 2018 11:04 am
I'm using the Techline ESI and I see nothing of the C101 connector end view. I've attached the Engine Controls Connector End Views.
1997 Engine Controls Connector End Views.docx [44.97 KiB]
Downloaded 131 times
-Andrew-
PostPosted: Thu Oct 11, 2018 12:46 pm
'05 STS-4
'97 LeSabre
That does help, it at least shows what pin on the original PCM was controlling the gauge. I'll have to see if I saved the original harness, and hopefully trace it back from there.
Runs:
Doesn't run:
There are no new unread posts for this topic. NEW Factory Service Manuals for the '97!
94SilverSSEi
Mon Dec 27, 2010 5:31 am
enslow View the latest post
There are no new unread posts for this topic. repair manuals
JayGXP
Wed Jun 25, 2008 4:00 pm
clm2112 View the latest post
There are no new unread posts for this topic. 97 vs 2005 bonneville shop manuals
bonnelover
Sun Oct 24, 2010 12:40 pm
bonnelover View the latest post
There are no new unread posts for this topic. 1992-1995 Bonneville manuals, window stickers, promos LOTS!
carguyblack
Thu Mar 10, 2016 5:35 pm
carguyblack View the latest post
There are no new unread posts for this topic. Attachment(s) Service Manual for the 2000?
Zeik75
Sun Nov 17, 2013 7:52 pm
Levi View the latest post
