It is currently Fri Mar 22, 2019 6:20 am
PostPosted: Tue Jun 19, 2018 7:51 am
Year and Trim: 2000 SE
2002 SSEI
Can someone explain the difference and what would be required to use an L32 (series III supercharged) fuel rail on a 2002 L67 pontiac bonneville? I read somewhere that I would need to add a pressure regulator that is on the L67 fuel rail. What else is required? Do you block of the return fuel line do you connect them so they are in a loop? I don't have the knowledge to understand what the differences are and why they made the change from return to returnless on the newer models.
PostPosted: Tue Jun 19, 2018 9:40 am
A stock return system pressurizes the system between the pump and the FPR (passes injectors). The FPR bleeds off any excess through the return line to the tank.
A return-less system pressurizes the system in the same way but varies the pressure via the pump and doesn't return. So, there's only one port on the fuel rail vs. 2 for a return system.
What you can do if you want to use the L32 fuel rail is plumb the stock L67 feed line from the tank into a 3 port aftermarket FPR. The FPR will have a pressurized outlet that goes to the returnless rail and the 3rd port will bleed off excess pressure to the return line. I ran a setup like this in my i30 for like 8 years.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
There are no new unread posts for this topic. help with fuel line connection to fuel rail
SPLLOUDER
18
7963
Mon Apr 01, 2013 4:19 pm
SPLLOUDER View the latest post
There are no new unread posts for this topic. 96 SE fuel line
wlas
Fri May 04, 2012 8:50 pm
RogueSSEi View the latest post
There are no new unread posts for this topic. Fuel Line Replacement
putertopia
Thu Sep 11, 2008 12:42 pm
putertopia View the latest post
There are no new unread posts for this topic. Fuel Line Solution?
Tricked-T
Wed Mar 10, 2010 11:30 pm
Tricked-T View the latest post
There are no new unread posts for this topic. fuel line clips
MattStrike
Sat Nov 08, 2014 10:09 pm
