It is currently Wed Jan 23, 2019 7:45 pm
 Post subject: Freeze plug leaking
PostPosted: Sat Apr 21, 2018 10:51 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
So I finally found the coolant leak on my '89
Freeze plug behind the starter motor (on the block) is leaking, looks like corrosion caused it.
I've never replaced a freeze plug before, but I figure it can't be that hard. Drill a hole in it, slide hammer it out, install new plug.
The last time I had a shop replace the plugs in a block, they used some sort of brown (I think) sealant on them. I'm not sure what it was, but I also have to consider that this will be an 'on car' service to fix it, and it has to be done as cheap as possible. So unless you all know where I can get a free block heater...
Can a freeze plug be installed without any special tools? (A task I'm currently using the magic of google to research as well)
Runs:
Doesn't run:
 Post subject: Re: Freeze plug leaking
PostPosted: Sat Apr 21, 2018 11:59 pm
Assuming it's a slow leak, have you tired the GM coolant sealing pellets? It might be worth a shot depending how much you really feel like messing with with the plug.
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Sun Apr 22, 2018 8:57 am
i had a small leak from heater plug - put some stop leak(high quality) and it works great on tiny leaks - if its rotted, it may work but only temp.
PostPosted: Mon Apr 23, 2018 12:49 am
I was gonna say the cooling system pellets too.
Otherwise, the one way I do it without a freeze plug removing tool (which kinda does what you were thinking), is to take a screwdriver, Tap the screwdriver on one side of the freeze plug and it should rotate/flip the other end out in the bore. From there, just grab it with a pair of pliers and work it out.
PostPosted: Mon Apr 23, 2018 9:38 am
'05 STS-4
'97 LeSabre
While I would love to try something like the cooling system stop leak, it's actually more expensive than a new freeze plug. So I'll give it a go this weekend.
Runs:
Doesn't run:
PostPosted: Mon Apr 23, 2018 12:04 pm
Here is a video of what I was trying to explain above.
https://www.youtube.com/watch?v=Cru1X9hbZ20
There are no new unread posts for this topic. My experience with Johnsen's Freeze 12, R-12 replacement
John Deere Boy
Sat Jul 24, 2010 6:28 pm
John Deere Boy View the latest post
There are no new unread posts for this topic. Anyone had leaking 00+ trans cooler lines?
Roadrunner
Tue Feb 19, 2013 3:34 pm
There are no new unread posts for this topic. Water leaking into back seat
MurderMitten
Thu May 15, 2014 11:28 am
There are no new unread posts for this topic. Leaking Radiator (Going to replace, Parts Ordered)
Alibi
31
1863
Thu Oct 02, 2008 4:02 pm
Alibi View the latest post
There are no new unread posts for this topic. spark Plug?
irish91983
Fri Feb 06, 2009 3:49 pm
irish91983 View the latest post
cron
