It is currently Sat Mar 23, 2019 4:43 pm
PostPosted: Mon Mar 19, 2018 12:13 am
Year and Trim: 1999 Pontiac Bonneville SSEi
Decided to buy some 40% stiffer with 1.5" lowering springs for my fw1 suspension. I'm looking into buying some wheel spacers so the wheels are flush with the body. I've read lots of your posts on the forums and absolutely adore your car (95naSTA) which is inspiring me to do this. I drive a 99 SSEi.
1995 SLE - First Car, 275k running/looking strong
1999 SSEi - New bae, Sleeper wannabe with 218k and growing. TEPs Stage 3. Engine work soon.
PostPosted: Mon Mar 19, 2018 6:21 am
Very flattered. Thank you.
Spacer size depends on your wheel width, camber and if you're going to roll your rear fenders or not. I used to have a general rule of thumb memorized and I also wrote a guide on another site but both are gone.
What I can say off hand is the 16x8" 1st gen GP cross laces makes for a great oem+ flush setup but it requires rear fender rolling if lowered. They have a 25mm offset. So you can work backwards from there.
https://www.willtheyfit.com/index.php?w ... offset2=19
07 Infiniti G35s 6MT
05 Suzuki DRZ400S
PostPosted: Mon Mar 19, 2018 10:30 am
Not exactly going to slam my car but just enough to look good and handle better. Hopefully i wont have to roll them. But I am using the oem slant 5's wheels. They use the ame tire as my crosslaces on my other Bonneville (95). 225 / 60 R16. I wont be doing much camber as far as I know.
PostPosted: Tue Mar 20, 2018 2:29 pm
So with the rear, I was rubbing occasionally with a good offset, 2" drop springs and an empty trunk. With 1.5" springs, 4 passengers and/or a full trunk, you would be in a similar spot.
05 Suzuki DRZ400S
PostPosted: Tue Mar 20, 2018 9:35 pm
Now what about the compressor kicking on it the rear? How can I combat that in order for it to not turn on all the time. I feel like I could adjust it somehow
PostPosted: Wed Mar 21, 2018 10:47 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
You should be able to adjust the linkage on the sensor.
Runs:
Doesn't run:
There are no new unread posts for this topic. style question 1992 Bonnie
nickirae
Fri Dec 05, 2008 11:12 pm
There are no new unread posts for this topic. Bonnie III, down again
Djkthegame
Sat Apr 02, 2011 9:33 pm
Djkthegame View the latest post
There are no new unread posts for this topic. Ode to the Bonnie
WhiteArrow3800
Tue Aug 11, 2009 8:10 pm
There are no new unread posts for this topic. Bonnie down
GoldenBullet
12
1213
Thu Sep 30, 2010 9:04 am
There are no new unread posts for this topic. Tool set for the Bonnie!
viper79
Tue Oct 27, 2015 10:53 pm
Zeik75 View the latest post
cron
