It is currently Wed Jan 23, 2019 11:27 pm
PostPosted: Thu Feb 01, 2018 12:41 pm
Year and Trim: 2005 Pontiac Bonneville GXP
Need to remove the driver door (damaged) and replace with a new(er) one. Where is the plug for the electrical harness to the driver door ? Inside the door or inside the "body"/chassis in front of the door opening ?
Trying to figure this out before I start pulling it all apart. Hoping that I can start taking off panels and such in the right direction. (The guy I bought the door from cut all the wires where the harness feeds into the chassis at the front of the door opening). If the connector is in the chassis/body work, then I will have to pull the harness out of the existing door and move it over. or spice a LOT of wires. Hoping the connector is inside the door.
Thanks in advance !
PostPosted: Thu Feb 01, 2018 7:29 pm
Almost 100% sure the connector is inside the door, but it's been a while since I've gone inside mine.
PostPosted: Thu Feb 01, 2018 7:48 pm
according to GMSI it's in the door, https://drive.google.com/open?id=1EhVpq ... 1TLKh5CPuP (says left door similar - doesn't show the left door in GMSI, but looks like you lucked out.
3.8L V6 SC, 180*T (Drilled),
PostPosted: Thu Feb 01, 2018 8:48 pm
Year and Trim: 2002 Park avenue
I know this isnt my thread, but thanks Jeff for the info on hard wiring my radar detector. I would have PM'ed you back but since im too new I guess im not aloud to send PMs yet.
PostPosted: Thu Feb 01, 2018 11:02 pm
Your most welcome.
PostPosted: Fri Feb 02, 2018 12:26 pm
Thank you !! That makes things much easier. :wink:
PostPosted: Sun Feb 04, 2018 6:47 pm
The connector for the front doors are inside the body for a 2005. The picture shown in the above post is actually a rear door but similar connections exist for the 2000 and perhaps 2001 front doors. For some reason they are different than later years which I suspect was to improve protection from the elements. To access the connector you need, you must remove the brake pedal assembly (or at least move it out of the way) and of course the LF sill plate. The connector you want is also a different style than shown in that diagram. Yours will be a Delphi Lever Lock 150/280 mixed style connector. It is the same connector as your driver's door trim panel (blue lever that you need to flip up to release). Oh yeah, you're going to find it to be a pain to access. Some people cut the heavy rubber sound barrier that the wiring passes through in the foot well to better access it. This isn't necessary, but can make it easier. If you do cut it, be VERY careful. The body shop that fixed my car after it was hit by a snow plow cut it. They also sliced open the sunroof drain hidden behind it! This was one factor in adding to interior water leaks.
PostPosted: Mon Feb 05, 2018 11:01 am
I don't know if you'll be able to see the photos or not (because they are hosted on photobucket), but this is a project I did a while ago. Many of the pictures show the area you need to access and the connector you're looking for.
post449450.html
There are no new unread posts for this topic. Driver Door Latch
DTadlock99
Thu Feb 08, 2018 6:01 pm
dougtoth View the latest post
There are no new unread posts for this topic. How to convert 2001-2005 Bonneville to 2000 Door Light
SPLLOUDER
Thu May 09, 2013 4:02 pm
SPLLOUDER View the latest post
There are no new unread posts for this topic. Looking at buying a 2005 GXP vs 2005 SLE vs 2003 SSEi
7tcatvert
33
4237
Sun Feb 19, 2012 2:07 am
There are no new unread posts for this topic. Wiring harness
Tricked-T
Mon May 04, 2009 4:45 pm
Tricked-T View the latest post
There are no new unread posts for this topic. Engine wiring harness
KnightBonne02
Sun Jan 04, 2015 1:02 pm
KnightBonne02 View the latest post
