It is currently Thu Jan 17, 2019 4:24 am
 Post subject: TPS
PostPosted: Sat Jan 13, 2018 3:23 pm
Year and Trim: 1997 Bonneville sse
I have a 1997 bonneville sse..... my check engine light came on and the code was po121 for a throttle position sensor.... I buy a new 1 n put it on
..... now it's saying there's not enough voltage from the tps. CAN ANYONE help me understand what I Need to do
 Post subject: Re: TPS
PostPosted: Sat Jan 13, 2018 8:05 pm
Year and Trim: 1993 SSE
Member since Nov 2003
Can't really help, but I did buy a TPS from carquest that only lasted a month. It might be worth returning for a replacement. In my case (series 1) the engine died every time i touched the throttle.
1993 SSE Since 11-12-2000
2011 Camaro 2SS
2006 Silverado 3500 4x4
PostPosted: Sat Jan 13, 2018 9:37 pm
use this to est it..............http://easyautodiagnostics.com/gm/3.8L/ ... n-sensor-1
PostPosted: Sat Jan 13, 2018 10:25 pm
Was it mounted properly? On some of them it's easy to get the lever of the tps sensor mounted on the wrong side of the lever on the throttle body.
PostPosted: Sun Jan 14, 2018 8:23 am
I will get my mechanic over today and have him readjust and reapply the tps and thanks so much for the testing method really will use that after....
PostPosted: Sun Jan 14, 2018 8:53 am
It doesn't die until I'm trying to park and need to hit the gas a little..... I hate dealing with sensors ..... it drives the same for the most part except when it chooses to cut off...
PostPosted: Sun Jan 14, 2018 7:58 pm
if the tps resets ok, I would next test/inspect the IAC.
PostPosted: Mon Jan 15, 2018 12:20 am
This is a case where you want to inspect the wiring, give it a wiggle while it's running and see if you have any problems. You should have a 5v reference and a ground wire, then a signal wire going to the computer.
