It is currently Thu Feb 21, 2019 9:38 pm
 Post subject: 4t65 issues...
PostPosted: Fri Dec 22, 2017 9:51 pm
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Working on my 1997 LeSabre again. 1998 4t65HD, 2002 L67, 1998 H-body NA harness with ZZP adapter to make it work with the L67. PCM is from the 1998 H-body, flashed and tuned for the L67.
Trans starts in 3rd gear, if you override it to 1st it feel like it starts in 2nd gear. Not sure what I could have missed during the rebuild, has all new electronics inside, and some upgraded hard parts. I doubt it's from the tune. There is a whining noise coming from something, sounds like it's under the supercharger. Not your typical transmission pump whine though, sounds like some weird lower pitched supercharger whine or something with an odd vacuum leak. Thoughts before I tear it open again? Trans was working before the refresh when I broke the input shaft. Not sure if the noise is related to the trans issue.
Runs:
Doesn't run:
 Post subject: Re: 4t65 issues...
PostPosted: Sat Dec 23, 2017 12:00 am
probably something isn't sealing properly. Did you do an air test on it to make sure that the clutches engaged?
PostPosted: Sat Dec 23, 2017 12:37 am
'05 STS-4
'97 LeSabre
I've heard this a few times now - knowing how the 4t65 works, each up shift is only engaging additional clutch packs. So All of the lower gear clutch packs are working if I have 3rd gear, right?
Runs:
Doesn't run:
There are no new unread posts for this topic. Another 4T65 Down
Jfridge92
Sat Dec 23, 2017 9:31 pm
Roadrunner View the latest post
There are no new unread posts for this topic. 4T65, Dex-VI, and the DIY Shift Kit
LeSabre in Buffalo
Tue Nov 03, 2009 7:13 pm
There are no new unread posts for this topic. 4T60 & 4T65
WhiteArrow3800
Fri Aug 14, 2009 3:52 pm
There are no new unread posts for this topic. Odd 4t65 issue
MattStrike
Mon Feb 18, 2019 10:56 am
There are no new unread posts for this topic. 3800/4T65-e are VIN Tagged
2003 SSEi
Thu Oct 13, 2016 8:53 pm
96 SSEi View the latest post
