It is currently Wed Feb 20, 2019 9:09 am
PostPosted: Wed Dec 13, 2017 10:40 pm
Year and Trim: 2000 Buick LeSabre
Quote:
What are the symptoms of a bad oxygen sensor?
Symptoms of a Bad Oxygen Sensor:
When you have a bad oxygen sensor, your vehicle will run less efficiently, it can sometimes have a poor idle, erratic jerking at steady throttle, hard starting problems, cause the check engine light to come on, and will cause high fuel consumption.
Quote:
How do you know if your oxygen sensor is bad?
Check this list to see if it's time to replace YOUR vehicle's oxygen sensors:
Sudden decrease in fuel mileage....
Flashing check engine light or malfunction indicator lamp in the vehicle?s dash board....
Failure to pass smog....
Overall poor vehicle performance; rough idling, stalling, hesitation on acceleration, etc.
When do you guys change your upstream oxygen sensor ? Do you wait until there's a DTC ?
PostPosted: Wed Dec 13, 2017 11:22 pm
standard recommendation is 100,000mi I personally wouldn't push it past 75,000mi....it and the MAF sensor have some of the biggest affects on your fuel mileage.
3.8L V6 SC, 180*T (Drilled),
PostPosted: Thu Dec 14, 2017 12:29 pm
166k miles on the original O2 and everything appears to be fine. But I guess it might be time for a change soon.
PostPosted: Thu Dec 14, 2017 4:38 pm
Change it/them when it/they becomes a problem. Actually first, I would try cleaning them and see if that buys you some additional time.
There is no need to change them at 75k or 100k or whatever. I think that's my lulz for the day.
Never had service bulletins that told us to change HO2S's because "when they reach a pre-determined mileage..."
PostPosted: Thu Dec 14, 2017 5:12 pm
yes, dont throw parts at your ride just cause - if you have 100 buck scanner, you can see their voltages and then determine if they are working within the expected range and not slow or stuck - not very expensive but clean all 3 first - o2 x 2 and maf.
PostPosted: Fri Dec 15, 2017 3:59 pm
:banana:
There are no new unread posts for this topic. oxygen sensor
Merrillspontiac
Mon Mar 22, 2010 6:37 pm
wjcollier07 View the latest post
jtbj06
Fri May 29, 2009 10:47 pm
repinS View the latest post
There are no new unread posts for this topic. To change or not change tranny fluid
2000GreySSEi
12
1928
Wed May 18, 2011 2:47 pm
comatoast View the latest post
There are no new unread posts for this topic. Oil Change.
Sacaledus
14
2211
Tue Apr 06, 2010 9:31 pm
There are no new unread posts for this topic. oil change on my 04 gxp
lilpat59
15
979
Wed Dec 05, 2012 12:48 pm
